Install dialog does not start from install URL
Posted: Monday 30 January 2023 16:36
Greetings, I am very new to Domoticz.
I have created a raspberry pi 64bit on a pi4 with 8Gb RAM.
when I try to run sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
All I see if the following.
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev...
The installation dialog never starts.
If I try to start, then there is no deamon service. I assume that the installation was never carried out, but I have not clue where to go now.
Please advise.
Lawrence
::: You are root.
Please advise.
Lawrence
