Combine 2 scripts SolisCloud>Domoticz.
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
Goal: Import data from Soliscloud (API) in to Domoticz.
I have found 2 things:
From SolisCloud to PVOutput
 https://www.google.com/url?sa=t&source=web&rct=j&url=https://github.com/ZuinigeRijder/SolisCloud2PVOutput&ved=2ahUKEwjisvbcz-X8AhVmgf0HHQN2CuwQFnoECAsQAQ&usg=AOvVaw2-ZvilDGiqAwPW6vLvQIl3
And the PVOutput import plugin by Domoticz.
Can't find the python plugin.py
My python skills are bad and want to ask someone that combine these two so that Domoticz import the data without the PVOutput step.
sincze
Domoticz version: 2024.4
Re: Combine 2 scripts SolisCloud>Domoticz.
Post by sincze »
Is doable.
Find your UID en Plant_ID and use my Pass2PHP script.
Solis has the same backend as Omnik and many more.
http://apic-cdn.solarman.cn/v/ap.2.0/plant/get_plant_device_list?uid=xxxx&plant_id=1yyyy
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
PeJeWe
Post by PeJeWe »
How do I use it in Domoticz?
sincze
Post by sincze »
PeJeWe wrote: Thursday 26 January 2023 17:34 How do I use it in Domoticz?
Have a look here, only needs 2 variables:
https://github.com/sincze/Domoticz/blob ... portal.php
Omnik and Solis (Login at https://m.ginlong.com/ not soliscloud to obtain UID and PLANTID)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
