Control OTGW over Wifi by MQTT and Domoticz
Posted: Sunday 15 January 2023 13:46
by Bluebird
I have connected the OTGW by Wifi and MQTT to Domoticz.
I see all the OTWG parrameters in Domoticz in the form of devices.
But what is the way to change these parrameters?
Ik MQTT explorer is see changing the domoticz/out items, but how to control the OTGW?
Thanks in advance
Henk
Re: Control OTGW over Wifi by MQTT and Domoticz
Posted: Sunday 15 January 2023 14:13
by willemd
I have OTGW connected via USB and then I can use the following dzvents command for example to switch the setpoint to 16 degrees.
domoticz.openURL('http://127.0.0.1:8080/json.htm?type=command&param=sendopenthermcommand&idx=8&cmnd=TC=16')
where 8 is the hardware idx of the OTGW (menu "setup", "hardware")
Don't know whether it is different in your setup.
Posted: Sunday 15 January 2023 19:44
by waltervl
Why over MQTT and not the build in OTGW gateway? See wiki https://www.domoticz.com/wiki/Opentherm_Gateway_OTGW
Posted: Wednesday 18 January 2023 22:14
by Bluebird
Thanks for the replies!
Problem solved!
But the documentation is not very clear en spread over several places.
Posted: Wednesday 18 January 2023 23:58
by waltervl
Tell us more, how did you solve it and what documentation did you use? This for the next user that runs into this issue. If needed I can update the Domoticz wiki. I do not have a OTGW so for me I am relying on the info from you users.
