Lua scripts suddenly not working anymore
Posted: Friday 06 January 2023 17:21
Today i noticed that many of my lua script suddenly aren't working anymore after a reboot
All the scripts haven't been changed recently, but they all have one thing in common: They use a function to determine if the current time is between a given time frame.
The log states:
What could be causing these problems? Has there been a lua change recently?
function timebetween(s,e)
timenow = os.date("*t")
year = timenow.year
month = timenow.month
day = timenow.day
s = s .. ":00" -- add seconds in case only hh:mm is supplied
e = e .. ":00"
shour = string.sub(s, 1, 2)
sminutes = string.sub(s, 4, 5)
sseconds = string.sub(s, 7, 8)
ehour = string.sub(e, 1, 2)
eminutes = string.sub(e, 4, 5)
eseconds = string.sub(e, 7, 8)
--Srise = domoticz.variables('Sunrise').value -- Sensor showing current setpoint
t1 = os.time()
t2 = os.time{year=year, month=month, day=day, hour=shour, min=sminutes, sec=sseconds}
t3 = os.time{year=year, month=month, day=day, hour=ehour, min=eminutes, sec=eseconds}
sdifference = os.difftime (t1, t2)
edifference = os.difftime (t1, t3)
isbetween = false
if sdifference >= 0 and edifference <= 0 then
isbetween = true
--print(" s:" .. s .. " e:" .. e .. " sdifference:" .. sdifference.. " edifference:" .. edifference)
return isbetween
Srise = otherdevices['Sunrise']
Sset = otherdevices['Sunset']
if timebetween(Srise,Sset) and tonumber(otherdevices['Lux woonkamer']) <= tonumber(13000) and otherdevices['Verlichting - Eettafel dimmer'] == 'On' and otherdevices['Verlichting - TV'] == 'Off' and otherdevices['Verlichting - Piano'] == 'Off' and otherdevices['Verlichting - Bank'] == 'Off' then
commandArray['Verlichting - TV'] = 'On'
commandArray['Verlichting - Piano'] = 'On'
commandArray['Verlichting - Bank'] = 'On'
print("Low light, turn on other lights")
elseif timebetween(Srise,Sset) and tonumber(otherdevices['Lux woonkamer']) > tonumber(13000) and otherdevices['Verlichting - Eettafel dimmer'] == 'On' and otherdevices['Verlichting - TV'] == 'On' and otherdevices['Verlichting - Piano'] == 'On' and otherdevices['Verlichting - Bank'] == 'On' then
commandArray['Verlichting - TV'] = 'Off'
commandArray['Verlichting - Piano'] = 'Off'
commandArray['Verlichting - Bank'] = 'Off'
print("Low light ended, turn off other lights")
2023-01-06 17:10:00.666 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:11:00.352 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:12:00.392 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:13:00.373 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:14:00.384 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:15:00.402 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:16:00.409 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:17:00.427 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:18:00.459 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
2023-01-06 17:19:00.514 Error: EventSystem: in Verlichting - low light: [string "function timebetween(s,e) ..."]:16: field 'sec' is not an integer
