Lua time question
Posted: Friday 06 January 2023 14:26
If I want to override a temperature setting in an Evohome system through the API, I use the updateSetPoint command. This command takes three parameters: temperature, setting ('TemporaryOverride' or the less readable 'domoticz.EVOHOME_MODE_TEMPORARY_OVERRIDE') and the datetime until the setting is valid. If I omit the datetime, the setting will go back to the normal setting at the moment the normal program changes. The datetime is in ISO 8601 format e.g.: "2023-06-01T13:41:00Z".
I made a presence detection with a virtual switch that changes only at the moment the house gets empty or someone enters again. If the house is left, I override the normal Evohome setting. I want to keep that setting until 4:00 in the night. If someone enters before that time the Evohome immediately goes back to the normal schedule, otherwise it does at 4:00. My problem is the time setting for the Evohome. I use the Lua time and date function:
This works at the moment in CET but will this also work in daylight saving time (CEST), when I'm on UTC+2? Does Domoticz change to and from DST on the last Sundays of March and October? I know it won't work correctly in those two night but that's a problem I accept.
Peter
-- Don't worry, in my actual code I don't use this much lines and parameters :-)
secsCurrentUTC = os.time() % (24 * 60 * 60) -- seconds since midnight in UTC
secsCurrentTime = secsCurrentUTC + 60 * 60 -- seconds since midnight in my timezone (Central European Time, CET = UTC+1)
secsUntilMidnight = 24 * 60 * 60 - secsCurrentTime -- seconds until midnight
secsUntilEndtime = secsUntilMidnight + 4 * 60 * 60 -- seconds until next morning 4:00
datetimeEndtime = os.time() + secUntilEndtime -- the datetime for next morning 4:00
utcEndtime = os.date("!%Y-%m-%dT%TZ", datetimeEndtime) -- the UTC to pass to the updateSetpoint function
evohomeZonename.updateSetPoint(theTemperature, 'TemporaryOverride', utcEndtime)
Peter
