SQL-problem
Posted: Thursday 05 January 2023 12:47
by BartSr
I use this query in a dzVents script of late Waaren ( viewtopic.php?t=30725 )
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date '..
' FROM DeviceStatus a , Meter b WHERE AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
of course this is OK.
Now I modified to limit to output using:
' FROM DeviceStatus a , Meter b WHERE time(b.Date) = "07:00:01" AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
note extended where-clause : time(b.Date) = "07:00:01" AND
But ....
When I create the query in DB Browser for SQLite it's OK. Output as expected.
Same query in Domoticz scripts: no output. Logfile shows ERROR ==>> but no errormessage.
Anyone who knows how to solve?
Thanks.
-Bart
Re: SQL-problem
Posted: Thursday 05 January 2023 14:17
by willemd
"time" is probably not a function known within dzVents. You will have to use a different method to get the time part of the date field that you selected, depending on what type the date field is. Probably a string?
Re: SQL-problem
Posted: Thursday 05 January 2023 18:01
by BartSr
Date is datetime type. So how to get the timeselectio?
Re: SQL-problem
Posted: Thursday 05 January 2023 22:55
by willemd
Re: SQL-problem
Posted: Friday 06 January 2023 11:45
the time statement is in the SQL query so no DzVents option.
I think it has to do with formatting the string and DzVents gets confused? Try to play with quote ' and double quotes "
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date FROM DeviceStatus a , Meter b WHERE time(b.Date) = "07:00:01" AND a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
Re: SQL-problem
Posted: Friday 06 January 2023 16:37
by BartSr
Hi Waltervl,
Quotes, double quotes and square quotes. All the same.
Bart
Re: SQL-problem
Posted: Friday 06 January 2023 17:21
by willemd
and what about a backslash before the double quotes before and after the time ( so \"07:00:01\" ), to indicate to dzVents these should not be treated as double quotes but just past as is.
Re: SQL-problem
Posted: Friday 06 January 2023 17:44
Also there is a colon ":" in the string (due to the time 7:00:00 ) that perhaps mixes things up in lua table collects{}???
