Use of parameters in framework
JanJaap
Domoticz version: Dev
Post by JanJaap »
I'm struggling a bit with the Parameters as exposed by the plugin framework. According to documentation, you have a standard set (like address, port, user/pwd etc) plus 6 user defined (mode1..mode6). However, when you make something completely user defined, it is nicely displayed in the HW page, but cannot be accessed from the code. For example, adding this to the plugin definition:
        <param field="Scene1" label="Temp Away " width="50px" required="true" default="17.0" >
        <description><br/>==== Scene configuration ====</description>
        </param>
        <param field="Scene2" label="Temp Sleep " width="50px" required="true" default="18.0" />
        <param field="Scene3" label="Temp Home " width="50px" required="true" default="19.5" />
        <param field="Scene4" label="Temp Comfort " width="50px" required="true" default="20.0" />
Will generated this view:
Domoticz parameters.PNG (5.07 KiB) Viewed 520 times
But leads to these errors when trying to access them in the code:
2023-01-02 22:00:46.941 Error: Toon: if strCurrentTemp == Parameters["Scene1"]:
2023-01-02 22:00:46.941 Error: Toon: KeyError: 'Scene1'
So, long story short: would it be possible to use any user-defined parameter? It would be great to get rid of this 6 modes limitation......
In practice, a lot of plugins already have 2 Parameters:
- a refersh rate
- a debug logging selector
Re: Use of parameters in framework
I think this question has been asked before and the answer was (if I remember correctly) that it needs a complex change. Perhaps check GitHub issues on this topic.
FlyingDomotic
Post by FlyingDomotic »
This works well naming user parameters "Mode1" to "Mode6". Here's an example:
<plugin key="MqttMapper" name="MQTT mapper with LAN interface" author="Flying Domotic" version="1.0.4">
    <description>
      MQTT mapper plug-in<br/><br/>
      Maps MQTT topics to Domoticz devices<br/>
    </description>
    <params>
        <param field="Address" label="MQTT Server address" width="300px" required="true" default="127.0.0.1"/>
        <param field="Port" label="Port" width="300px" required="true" default="1883"/>
        <param field="Username" label="Username" width="300px"/>
        <param field="Password" label="Password" width="300px" password="true"/>
        <param field="Mode1" label="JSON mapping file to use" width="300px" required="true" default="MqttMapper.json"/>
        <param field="Mode6" label="Debug" width="100px">
            <options>
                <option label="Extra verbose" value="Verbose+"/>
                <option label="Verbose" value="Verbose"/>
                <option label="Normal" value="Debug"/>
                <option label="None" value="Normal" default="true"/>
            </options>
        </param>
    </params>
</plugin>
Values are read back using
Parameters["Mode1"]
to
Parameters["Mode6"]
