setpoint control with HA Bridge and Alexa?
Posted: Sunday 01 January 2023 10:40
by renerene
I use Alexa + HA-Bridge to control light and screens with "turn on" voice commands.
However, is it also possible to sent values?
"Alex, set thermostat to 18"?
Re: setpoint control with HA Bridge and Alexa?
Posted: Tuesday 28 March 2023 17:21
by firesfinx
Yes that is possible. You can dim a light or send a value from 0 to 100 to a domoticz dimmer device. I use this for lights, volume and tv channels. In HA-bridge create a domoticz device and add the following to the Dim Items > Target Item field:
http://<IP DOMOTICZ>:<PORT DOMOTICZ>/json.htm?type=command¶m=switchlight&idx=<ID DIMMER&switchcmd=Set%20Level&level=${intensity.percent}
For thermostats the domoticz device changes and so the command. In HA-bridge create a domoticz device and add the following to the Dim Items > Target Item field:
http://<IP DOMOTICZ>:<PORT DOMOTICZ>/json.htm?type=command¶m=setsetpoint&idx=<ID TERMOSTAT>&setpoint=${intensity.percent}
Hope this helps
Posted: Tuesday 28 March 2023 18:45
by renerene
firesfinx wrote: Tuesday 28 March 2023 17:21
Yes that is possible. You can dim a light or send a value from 0 to 100 to a domoticz dimmer device. I use this for lights, volume and tv channels. In HA-bridge ......
Hope this helps
Sorry, this does not help. It is only part of the solution. How to convert the voice commands from alexa into parameters?
As far as i know alexa can only handle on / off switches. It would be great if you could somehow convert the spoken number to a variable.
Posted: Tuesday 28 March 2023 23:01
by philchillbill
With HA Bridge you only have access to Philips Hue light commands. So you can turn switches on and off and set dim levels, basically. Back when I used HA Bridge in 2016 I used to have switches called e.g. ‘set living room to 22’ and when I turned it on I used the script:// command in the switch to run a script that changed the thermostat. Worked fine for pre-meditated temps. Bit contrived for sure but if you really want to stick with HA Bridge then you could make it work.
Posted: Tuesday 28 March 2023 23:27
by renerene
yes, i work with "turn thermostat 18 on" after naming devices Thermostat18 ...19,:etc in HAbridge
