Change in data returned by JSON API w parameter devices_list
Posted: Monday 19 December 2022 15:27
I migrated Domoticz from a PI3 to a HP thin client running Debian 11. For that I had to compile Domoticz to get a 32 bit module for machine Intel 80386.
After that I got errors in my LUA script using the JSON API with parameters devices_list as the content of the data returned is different.
As shown below the field "value" is now replaced by field "idx".
Below data returned for each platform by calls to getversion and devices_list.
On Raspberry PI3:
json with type=command¶m=getversion
json with type=command¶m=devices_list
On HP thin client:
json with ype=command¶m=devices_list
I found no documentation on why this change. Possibly this could impact other flavors of scripts.
For compatibilty sake I wish to maintain one set of scripts regardless they run on a PI or a i386 machine.
I wonder if there is an option I need to set for the compilation to control this or if my problem is due to a change in the source I used vs what is in the pre-built package I used on my PI3 ?
On Raspberry PI3:
"DomoticzUpdateURL" : " .......php?channel=stable&type=release&system=linux&machine=aarch64",
"HaveUpdate" : false,
"Revision" : 14606,
"SystemName" : "linux",
"UseUpdate" : true,
"build_time" : "2022-11-05 13:05:35",
"dzvents_version" : "3. 1. 8",
"hash" : "eea9db734",
"python_version" : "3 .7 .3 (default, Oct 31 2022, 14:04:00) \n[GCC 8 .3 .0]",
"status" : "OK",
"title" : "GetVersion",
"version" : "2022. 2"
"result" :
"name" : "Automation",
"value" : "53"
On HP thin client:
"DomoticzUpdateURL" : " ......php?channel=stable&type=release&system=linux&machine=x86_64",
"Revision" : 14606,
"UseUpdate" : true,
"build_time" : "2022-12-15 08:45:45",
"hash" : "387ba0e4b",
"python_version" : "3. 9. 2 (default, Feb 28 2021, 17:03:44) \n[GCC 10. 2. 1 20210110]",
"status" : "OK",
"version" : "2022. 2 (build 14839)"
"result" :
"idx" : "53",
"name_type" : "Automation (Light/Switch/Switch)"
