Tasmota energy meters, no decimals
HarryB
Domoticz version: 2022-2
Post by HarryB »
Hi Team,
I have about 11 Tasmota devices connected through MQTT (Mosquito) and it works perfect.
The only thing, I would like to see are the values with decimals on the energy meters, I have the right setting in "Settings" (decimals)
In the Tasmota Device Manager I see that the MQTT transmitted values have decimals, so it is rounded or changed somewhere within Domoticz.
Within the virtual device there is no setting for this either.
Anyone?
Raspberry 4
Domoticz 2022.2
AEOTEC Z-Stick Gen5
RFXCom
Mosquito on Synology
kofec
Re: Tasmota energy meters, no decimals
Post by kofec »
Did you resolve your issue ?
@waltervl Thanks the solution works, just need to figure out how to get the data from two channel energy meters like the DUAL R3. I did publish this issue in the forum, but nothing came back.
I think this is the same user and issue: https://github.com/domoticz/domoticz/issues/5514
Conclusion: Use Tasmota Rules to send the correct values (thanks @kofec for the support)
