MQTT: Failed to start, return code: 14/Connection refused (Check IP/Port)
Posted: Friday 16 December 2022 21:31
by marktn
Anybody who can help me with MQTT?
After sudo apt update && sudo apt upgrade
In my log of domoticz: MQTT: Failed to start, return code: 14/Connection refused (Check IP/Port)
pi@raspberrypi:~ $ systemctl status mosquitto.service
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2022-12-16 21:25:24 CET; 28s ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 4684 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 4685 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 4686 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 4687 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 4688 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 4688 (code=exited, status=1/FAILURE)
Dec 16 21:25:24 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Dec 16 21:25:24 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Dec 16 21:25:24 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Dec 16 21:25:24 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Dec 16 21:25:24 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Dec 16 21:25:24 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
pi@raspberrypi:~ $ ● mosquitto.service - Mosquitto MQTT Broker
Re: MQTT: Failed to start, return code: 14/Connection refused (Check IP/Port)
Posted: Friday 16 December 2022 22:03
by JuanUil
Posted: Friday 16 December 2022 22:07
by marktn
Okay... Hopefully somebody can help.
My Backup is running is fine.
Posted: Friday 16 December 2022 23:39
by ferrosk
Do you have this log file /var/log/mosquitto/mosquitto.log? Check if there are any errors...
Posted: Saturday 17 December 2022 10:29
by marktn
ferrosk wrote: Friday 16 December 2022 23:39
Thanks for your support! Any idea what to do?
log
1669305336: mosquitto version 1.6.12 starting
1669305336: Config loaded from /etc/mosquitto/mosquitto.conf.
1669305336: Opening ipv4 listen socket on port 1883.
1669305336: Error: Address already in use
1669305337: mosquitto version 1.6.12 starting
1669305337: Config loaded from /etc/mosquitto/mosquitto.conf.
1669305337: Opening ipv4 listen socket on port 1883.
1669305337: Error: Address already in use
1669393843: mosquitto version 1.6.12 starting
1669393843: Config loaded from /etc/mosquitto/mosquitto.conf.
1669393843: Opening ipv4 listen socket on port 1883.
1669393843: Error: Address already in use
1669393844: mosquitto version 1.6.12 starting
1669393844: Config loaded from /etc/mosquitto/mosquitto.conf.
1669393844: Opening ipv4 listen socket on port 1883.
1669393844: Error: Address already in use
1669394062: mosquitto version 1.6.12 starting
1669394062: Config loaded from /etc/mosquitto/mosquitto.conf.
1669394062: Opening ipv4 listen socket on port 1883.
1669394062: Error: Address already in use
sudo service mosquitto status
Active: failed (Result: exit-code) since Sat 2022-12-17 10:16:41 CET; 10min ago
man:mosquitto(8)
Process: 813 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 814 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 815 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 816 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 817 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 817 (code=exited, status=1/FAILURE)
Dec 17 10:16:41 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Dec 17 10:16:41 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Dec 17 10:16:41 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Dec 17 10:16:41 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Dec 17 10:16:41 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Dec 17 10:16:41 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
pi@raspberrypi:/var/log/mosquitto $
sudo service mosquitto restart
Job for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xe" for details.
You have new mail in /var/mail/pi
pi@raspberrypi:~ $ sudo netstat -anp | grep 1883
tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 547/mosquitto
tcp 0 0 127.0.0.1:49362 127.0.0.1:1883 ESTABLISHED 320/node-red
tcp 0 0 127.0.0.1:49360 127.0.0.1:1883 ESTABLISHED 320/node-red
tcp 0 0 127.0.0.1:1883 127.0.0.1:49362 ESTABLISHED 547/mosquitto
tcp 0 0 192.168.1.5:44068 192.168.1.6:1883 ESTABLISHED 320/node-red
tcp 0 0 127.0.0.1:1883 127.0.0.1:49360 ESTABLISHED 547/mosquitto
tcp 0 0 192.168.1.5:44070 192.168.1.6:1883 ESTABLISHED 320/node-red
tcp6 0 0 ::1:1883 :::* LISTEN 547/mosquitto
pi@raspberrypi:~ $
Posted: Saturday 17 December 2022 19:52
by ferrosk
hello,
Apparently you have other mosquitto process already started/running and using port 1883 when you try to start mosquitto.service in parallel and fails because the port is already in use. Try to identify service which started the process using port 1883:
find PID of the process which is using port 1883:
example:
547/mosquitto
this means process
PID is
547
Then try to find service which started this process:
example:
sudo systemctl status
547
Don't you have another mosquitto i.e. running in Docker container?
Posted: Sunday 18 December 2022 10:59
by marktn
Thanks! I see somebody with experience.
No docker running or another mosquitto. Not that i know. I don't have a lot of experience with this.
Is this what you need?
pi@raspberrypi:~ $ sudo netstat -anp | grep :1883
tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 546/mosquitto
tcp6 0 0 ::1:1883 :::* LISTEN 546/mosquitto
pi@raspberrypi:~ $ ^C
pi@raspberrypi:~ $ sudo systemctl status 546
Warning: The unit file, source configuration file or drop-ins of rc-local.service changed on disk. Run 'systemctl daemon-reload' to reload units.
● rc-local.service - /etc/rc.local Compatibility
Loaded: loaded (/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: enabled)
Drop-In: /lib/systemd/system/rc-local.service.d
└─debian.conf
/etc/systemd/system/rc-local.service.d
└─ttyoutput.conf
Active: active (running) since Sat 2022-12-17 15:11:53 CET; 19h ago
Docs: man:systemd-rc-local-generator(8)
Process: 526 ExecStart=/etc/rc.local start (code=exited, status=0/SUCCESS)
Tasks: 1 (limit: 2200)
Memory: 1.5M
CGroup: /system.slice/rc-local.service
└─546 /usr/sbin/mosquitto -d
Dec 17 15:11:53 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Dec 17 15:11:53 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
pi@raspberrypi:~ $
Posted: Sunday 18 December 2022 13:43
by ferrosk
hello,
Check the content of /etc/rc.local file. Maybe you have a command to start mosquitto in it. In that case system tries to start one mosquitto by rc-local.service and another mosquitto by mosquitto.service. If it mosquitto command is present in /etc/rc.local comment it out or remove the line. Then do:
sudo systemctl daemon-reload
sudo systemctl start mosquitto
sudo systemctl status mosquitto
or reboot the system.
Posted: Sunday 18 December 2022 14:13
by marktn
ferrosk wrote: Sunday 18 December 2022 13:43
hello,
It was this,
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
exit 0
And changed it to this:
#!/bin/sh -e
# rc.local
# value on error.
# bits.
if [ "$_IP" ]; then
fi
#/usr/sbin/mosquitto -d
exit 0
status:
Active: failed (Result: exit-code) since Sun 2022-12-18 14:07:50 CET; 39s ago
man:mosquitto(8)
Process: 820 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 821 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 822 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 823 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 824 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
Main PID: 824 (code=exited, status=3)
Dec 18 14:07:50 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Dec 18 14:07:50 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Dec 18 14:07:50 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Dec 18 14:07:50 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Dec 18 14:07:51 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Dec 18 14:07:51 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
The error is the same..
Also did a reboot, to be sure. And checked the settings.
Maybe an idea,to do a remote desktop with teamviewer?
Posted: Sunday 18 December 2022 14:39
by ferrosk
as I can see now it fails with return code 3 which is different as before:
so check the log file /var/log/mosquitto/mosquitto.log what is the error now
Posted: Sunday 18 December 2022 14:50
by marktn
ferrosk wrote: Sunday 18 December 2022 14:39
1671284179: mosquitto version 2.0.12 starting
1671284179: Config loaded from /etc/mosquitto/mosquitto.conf.
1671284179: Starting in local only mode. Connections will only be possible from clients running on this machine.
1671284179: Create a configuration file which defines a listener to allow remote access.
1671284179: For more details see https://mosquitto.org/documentation/authentication-methods/
1671284179: Opening ipv4 listen socket on port 1883.
1671284179: Error: Address already in use
1671284179: Opening ipv6 listen socket on port 1883.
1671284180: mosquitto version 2.0.12 starting
1671284180: Config loaded from /etc/mosquitto/mosquitto.conf.
1671284180: Starting in local only mode. Connections will only be possible from clients running on this machine.
1671284180: Create a configuration file which defines a listener to allow remote access.
1671284180: For more details see https://mosquitto.org/documentation/authentication-methods/
1671284180: Opening ipv4 listen socket on port 1883.
1671284180: Error: Address already in use
1671284180: Opening ipv6 listen socket on port 1883.
1671284181: mosquitto version 2.0.12 starting
1671284181: Config loaded from /etc/mosquitto/mosquitto.conf.
1671284181: Starting in local only mode. Connections will only be possible from clients running on this machine.
1671284181: Create a configuration file which defines a listener to allow remote access.
1671284181: For more details see https://mosquitto.org/documentation/authentication-methods/
1671284181: Opening ipv4 listen socket on port 1883.
1671284181: Error: Address already in use
1671284181: Opening ipv6 listen socket on port 1883.
1671284340: mosquitto version 2.0.12 starting
1671284340: Config loaded from /etc/mosquitto/mosquitto.conf.
Posted: Sunday 18 December 2022 15:20
by ferrosk
according to timestamp (1671284340), the logs from last run are the following:
looks like no errors... strange
try stop / remove the log / start again and check status/logs:
sudo systemctl stop mosquitto
sudo rm /var/log/mosquitto/mosquitto.log
sudo cat /var/log/mosquitto/mosquitto.log
Posted: Sunday 18 December 2022 15:30
by marktn
ferrosk wrote: Sunday 18 December 2022 15:20
Still a failure..
pi@raspberrypi:~ $ sudo systemctl stop mosquitto
pi@raspberrypi:~ $ sudo rm /var/log/mosquitto/mosquitto.log
pi@raspberrypi:~ $ sudo systemctl start mosquitto
Job for mosquitto.service failed because the control process exited with error c ode.
pi@raspberrypi:~ $ sudo systemctl status mosquitto
Active: failed (Result: exit-code) since Sun 2022-12-18 15:28:07 CET; 5s ago
man:mosquitto(8)
Process: 1186 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exite
Process: 1187 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exite
Process: 1188 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, s
Process: 1189 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, s
Process: 1190 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (
Main PID: 1190 (code=exited, status=3)
Dec 18 15:28:07 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=10
Dec 18 15:28:07 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job
Dec 18 15:28:07 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Dec 18 15:28:07 raspberrypi systemd[1]: mosquitto.service: Start request repeate
Dec 18 15:28:07 raspberrypi systemd[1]: mosquitto.service: Failed with result 'e
Dec 18 15:28:07 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
[1]+ Stopped sudo systemctl status mosquitto
pi@raspberrypi:~ $ sudo cat /var/log/mosquitto/mosquitto.log
cat: /var/log/mosquitto/mosquitto.log: No such file or directory
Posted: Sunday 18 December 2022 15:40
by ferrosk
do you have config file /etc/mosquitto/mosquitto.conf present?
What if you you start it manually with default config (without using above config file):
sudo -u mosquitto /usr/sbin/mosquitto
Posted: Sunday 18 December 2022 15:43
by marktn
ferrosk wrote: Sunday 18 December 2022 15:40
The log is gone, nohting in there.
I can give you teamviewer access?
pi@raspberrypi:/var/log/mosquitto $ sudo systemctl status mosquitto
Active: failed (Result: exit-code) since Sun 2022-12-18 15:33:10 CET; 9min ago
man:mosquitto(8)
Process: 834 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 835 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 836 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 837 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 838 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
Main PID: 838 (code=exited, status=3)
Dec 18 15:33:10 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Dec 18 15:33:10 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Dec 18 15:33:10 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Dec 18 15:33:10 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Dec 18 15:33:10 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Dec 18 15:33:10 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
Posted: Sunday 18 December 2022 15:50
by ferrosk
ok you can send me ID/pass in Private Message
Posted: Sunday 18 December 2022 15:53
by marktn
ferrosk wrote: Sunday 18 December 2022 15:50
Send a private message, with the ID/Pass
Posted: Sunday 18 December 2022 17:16
by ferrosk
Just for reference. We fixed the problem via teamviewer.
When tried to start without using config file (default config):
it started OK.
When tried to start with using config file:
sudo -u mosquitto /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
it failed with error:
Error: Unknown configuration variable "listner".
The reason was typo in variable in the config file - it was fixed and started OK.
