problems with mqtt
Posted: Friday 16 December 2022 19:31
since yesterday I have a big problem with mosquitto mqqt.
The broker doesn't want to connect anymore.
In domoticz log I get:
when i ssh and give the command systemctl status mosquitto.service I get:
in /etc/mosquitto/mosquitto.conf I have:
strange is also that the problem is coming back even if i use a backup image of a working system!!
some more info:
Any help is highly appreciated!!!
Jan
2022-12-16 19:25:24.839 Status: MQTT: Worker stopped...
2022-12-16 19:25:25.851 Status: MQTT: Connecting to 192.168.2.21:1883
2022-12-16 19:25:25.851 Error: MQTT: Failed to start, return code: 14/Connection refused (Check IP/Port)Code: Select all
* mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2022-12-16 19:27:19 CET; 1min 45s ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 2792 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2793 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2794 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2795 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2796 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 2796 (code=exited, status=1/FAILURE)
CPU: 95ms
dec 16 19:27:19 PI4Nieuw systemd[1]: mosquitto.service: Failed with result 'exit-code'.
dec 16 19:27:19 PI4Nieuw systemd[1]: Failed to start Mosquitto MQTT Broker.
dec 16 19:27:19 PI4Nieuw systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
dec 16 19:27:19 PI4Nieuw systemd[1]: Stopped Mosquitto MQTT Broker.
dec 16 19:27:19 PI4Nieuw systemd[1]: mosquitto.service: Start request repeated too quickly.
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
listener 1883
allow_anonymous true
some more info:
pi@server5:~ $ mosquitto -v
1671219391: mosquitto version 2.0.11 starting
1671219391: Using default config.
1671219391: Starting in local only mode. Connections will only be possible from clients running on this machine.
1671219391: Create a configuration file which defines a listener to allow remote access.
1671219391: For more details see https://mosquitto.org/documentation/authentication-methods/
1671219391: Opening ipv4 listen socket on port 1883.
1671219391: Error: Address already in use
1671219391: Opening ipv6 listen socket on port 1883.
Jan
