Switching a Délonghi DNS80 Airdryer
Posted: Monday 12 December 2022 9:35
Long time since I had to ask a question here
I recently bought a Délonghi Tasciugo AriaDry Light DNS80 air dryer. I like to use it the bathroom. Because it's an "adsorption" dryer, with a Zeolit core, it produces quit some heat. Therefor I would also like to use it the heat the bathroom by turning it on several hours before we wake.
Quit easy to do, except that you can't unplug it, because of the heat.
This is a quote from the manual:
I see 3 scenarios:
1) Just cut the power, danger for remaining heat in the device.
2) Wait until the device doesn't consume a lot of electricity anymore and then cut the power. Downside is that it has to keep on running until humidity < 45%.
3) Use a double relay built in the device. One to switch the main power and one to switch the heater. That way I could stop the heater and shut off several minutes later. Downside: device must be opened, warranty voided etc.
Do you see any other points?
Do you guys think it would cause problems if I just cut the power?Important: Before unplugging from the mains, wait for the fan to stop. The fan remains in operation for about two minutes after the appliance is turned off to allow the heating element to cool down.
I see 3 scenarios:
