Backup script Domoticz gives me headaches please help...
Posted: Wednesday 07 December 2022 20:45
Hi, I am using the backup script below which I found on domoticz wiki site. The backup part works great but I can't get the last part where folders older than xx days have to be deleted.
The script gets stuck on the next part.
When I run the script on the raspberry it gets stuck as shown below. No error message.
Any help is very welcome.
Perhaps there is an easier way to delete older content folders than I highly recommend.
#!/bin/bash
# Sript to automatic backup some stuff from Domoticz
# Run script every day from crontab.
# Example: sudo crontab -e
# Place this line below in your crontab document:
# 0 1 * * * sudo ~/domoticz/scripts/domoticz_backup.sh
# Backup wil start every night at 1:00 hour past midnight
# LOCAL/FTP/SCP/MAIL/FILE PARAMETERS
SERVER="191.168.2.11" # IP of NAS, used for ftp
USERNAME="xxxxx" # FTP username of Network disk used for ftp
PASSWORD="xxxxxxxxx" # FTP password of Network disk used for ftp
DESTDIR="/tmp" # used for temorarily storage
DESTDIRNAS="Backups/Domoticz" # Path to your NAS backup folder
DOMO_IP="192.168.2.26" # Domoticz IP
DOMO_PORT="8086" # Domoticz port
DOMO_PATH="/home/pi/domoticz" # Path to your Domoticz folder on raspberry
TIMESTAMP=`/bin/date +%d-%m-%Y`
BACKUPFILE="domoticz_$TIMESTAMP.db" # backups will be named "domoticz_YYYYMMDDHHMMSS.db.gz"
BACKUPFILEGZ="$BACKUPFILE".gz
### END OF USER CONFIGURABLE PARAMETERS
### First remove old backups
sudo /bin/rm $DOMO_PATH/backups/*
### Create backup and ZIP it
sudo /usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > $DESTDIR/$BACKUPFILE
sudo gzip -1 $DESTDIR/$BACKUPFILE
sudo tar -zcvf $DESTDIR/domoticz_$TIMESTAMP.tar.gz $DOMO_PATH
### Send to Network disk through FTP
sudo curl -u "$USERNAME:$PASSWORD" --ftp-create-dirs "ftp://192.168.2.11/$DESTDIRNAS/$TIMESTAMP/"
sudo curl -s --disable-epsv -v -T "$DESTDIR/$BACKUPFILEGZ" -u "$USERNAME:$PASSWORD" "ftp://192.168.2.11/$DESTDIRNAS/$TIMESTAMP/"
sudo curl -s --disable-epsv -v -T "$DESTDIR/domoticz_$TIMESTAMP.tar.gz" -u "$USERNAME:$PASSWORD" "ftp://192.168.2.11/$DESTDIRNAS/$TIMESTAMP/"
### Remove temp backup file
sudo /bin/rm $DESTDIR/$BACKUPFILEGZ
sudo /bin/rm $DESTDIR/domoticz_$TIMESTAMP.tar.gz
# get a list of files and dates from ftp and remove files older than ndays
ftpsite="sftp -b- -oPort=22 $USERNAME@$SERVER"
putdir=$DESTDIRNAS
ndays=14
# work out our cutoff date
MM=`date --date="$ndays days ago" +%b`
DD=`date --date="$ndays days ago" +%d`
TT=`date --date="$ndays days ago" +%s`
echo removing files older than $MM $DD
# get directory listing from remote source
echo "
cd $putdir
ls -l
"|$ftpsite >dirlist
# skip first three and last line, ftp command echo
listing="`tail -n+4 dirlist|head -n-1`"
lista=( $listing )
# loop over our files
for ((FNO=0; FNO<${#lista[@]}; FNO+=9));do
# month (element 5), day (element 6) and filename (element 8)
# echo Date ${lista[`expr $FNO+5`]} ${lista[`expr $FNO+6`]} File: ${lista[`expr $FNO+8`]}
fdate="${lista[`expr $FNO+5`]} ${lista[`expr $FNO+6`]} ${lista[`expr $FNO+7`]}"
sdate=`date --date="$fdate" +%s`
# check the date stamp
if [ $sdate -lt $TT ]
then
# Remove this file
echo "$MM $DD: Removing ${lista[`expr $FNO+5`]} / ${lista[`expr $FNO+6`]} / ${lista[`expr $FNO+8`]}"
$ftpsite <<EOMYF2
cd $putdir
rm ${lista[`expr $FNO+8`]}
quit
EOMYF2
fi
doneThe script gets stuck on the next part.
echo"
cd $putdir
ls -l
"|$ftpsite > directory
* We are completely uploaded and fine
* Remembering we are in dir "Backups/Domoticz/07-12-2022/"
< 226 Transfer complete
* Connection #0 to host 192.168.2.11 left intact
removing files older than nov 23
