Basic plugin with DomoticzEx question
Posted: Tuesday 06 December 2022 21:00
by brjhaverkamp
Hello all,
I am trying to create a plugin, based on the Basetemplate.py
I am able to create some devices (or are they called units now?
BurnerSwitch = Domoticz.Unit(Name="BurnerSwitch", DeviceID="AduroHx", Unit=1, Type=244, Subtype=73, Switchtype=0).Create()
But I am not able to use the devices that are created.
It shows up under switches. But when I click the lightbulb it doesn't switch on.
It does call the onCommand callback and I can e.g. print something to the log, but I can not figure out how to change the state of the switch.
I'm pretty sure I'm missing something obvious. But most examples are still based on the old Domoticz framework, instead of DomoticzEx.
Can anyone give me a pointer?
Regards,
Bert
Re: Basic plugin with DomoticzEx question
Posted: Tuesday 06 December 2022 21:56
Zigbee2mqtt plugin is DomoticzEx so that could give some inspiration (I am not a programmer)
Posted: Wednesday 07 December 2022 20:57
by brjhaverkamp
Hi Waltervl,
Thanks. Indeed it is one of the few I could find. But the onCommand doesn't seem to have an update function. Or at least not that I could find/recognise.
I now got it working with the following code. But is this indeed the expected way? It looks quite convoluted. so any suggestion/advice is welcome.
def onCommand(self, DeviceID, Unit, Command, Level, Color):
        Domoticz.Log("onCommand called for Device " + str(DeviceID) + " Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
        if Devices[DeviceID].Units[Unit].nValue == 1:
            Domoticz.Log("Switching off: ")
            Devices[DeviceID].Units[Unit].nValue= 0
            Devices[DeviceID].Units[Unit].sValue= "Off"
            Devices[DeviceID].Units[Unit].Update()
        else:
            Domoticz.Log("Switching on")
            Devices[DeviceID].Units[Unit].nValue= 1
            Devices[DeviceID].Units[Unit].sValue= "On"
Posted: Wednesday 07 December 2022 23:06
Sorry, as mentioned I am not a programmer.
Posted: Thursday 08 December 2022 0:20
Posted: Thursday 22 December 2022 18:41
by brjhaverkamp
Hi Waltervi,
Just to close this thread: Thanks for the example!!.
It helped a lot! I got my basic Aduro plugin working.
Now working on expanding and cleaning up!
Regards,
Bert
