2022.2 Domoticz sources not compiling Topic is solved
meal
- Domoticz version: 2025.2
Context of the issue :
- Domoticz running on RPI3B+
- Python 3.7.3
- Current version used 2022.1 version 14338
I want to build domoticz 2022.2 version from latest beta sources and followed the procedure described in "https://www.domoticz.com/wiki/Build_Dom ... rom_source".
At domoticz compilation time of the file "domoticz_tester.cpp" I have the following error
In file included from /home/pi/DEV20200309/dev-domoticz/main/domoticz_tester.cpp:8:
/home/pi/DEV20200309/dev-domoticz/main/appversion.h:2:10: fatal error: ../appversion.h: Aucun fichier ou dossier de ce type
#include "../appversion.h"
compilation terminated.
make[2]: *** [CMakeFiles/domoticztester.dir/build.make:143: CMakeFiles/domoticztester.dir/main/domoticz_tester.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:446: CMakeFiles/domoticztester.dir/all] Error 2
make: *** [Makefile:171: all] Error 2
It seems that the file "dev-domoticz/appversion.h" is missing.
The file is not in the clone distribution "git clone https://github.com/domoticz/domoticz.git dev-domoticz"
For information I managed to build the 2022.1 Domoticz version from sources in June 2022 and in that version the content of the "dev-domoticz/appversion.h" was:
#define APPVERSION 14338
#define APPHASH "8d73c42d6-modified"
#define APPDATE 1652636840
At that time "domoticz_tester.cpp" was not part of the 2022.1 Domoticz sources distribution.
Did I miss something ?
I thank you in advance for your help.
BR
- Python 3.7.3
BR
meal
ferrosk
- Domoticz version: 2026.2
Re: 2022.2 Domoticz sources not compiling
It is not present just after 'git clone' but it is generated in this path by 'make' during build time. If not, then you are doing something wrong...meal wrote: Thursday 01 December 2022 11:28 It seems that the file "dev-domoticz/appversion.h" is missing.
Why are you trying to build Domoticz from sources? If not familiar with the process and you need latest beta version, you can download pre-compiled beta binaries resp. use './updatebeta' script to upgrade Domoticz.
Domoticz 2026.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
- kiddigital
The ‘CMake’ command before the actual `make` command should generate that file as far as I remember.
ferrosk
It is actually 'make' after CMake that generates it based on build target defined in CMakeLists.txtkiddigital wrote: Friday 02 December 2022 6:56 The ‘CMake’ command before the actual `make` command should generate that file as far as I remember.
From CMakeLists.txt:
# creates appversion.h using cmake script
ADD_CUSTOM_COMMAND(TARGET revisiontag COMMAND ${CMAKE_COMMAND}
-DSOURCE_DIR=${CMAKE_CURRENT_SOURCE_DIR}
-P ${CMAKE_CURRENT_SOURCE_DIR}/getgit.cmake)
MESSAGE(STATUS "###########################")
MESSAGE(STATUS "Compiling Revision #${ProjectRevision}")
# The version number.
set (domoticz_VERSION_MAJOR 2020)
set (domoticz_VERSION_MINOR 1)
set (domoticz_VERSION_PATCH ${ProjectRevision})
vagrant@debian-dzdev:/tmp$ git clone https://github.com/domoticz/domoticz.git dev-domoticz
Cloning into 'dev-domoticz'...
remote: Enumerating objects: 91727, done.
remote: Counting objects: 100% (305/305), done.
remote: Compressing objects: 100% (166/166), done.
remote: Total 91727 (delta 171), reused 253 (delta 139), pack-reused 91422
Receiving objects: 100% (91727/91727), 257.55 MiB | 12.21 MiB/s, done.
Resolving deltas: 100% (67529/67529), done.
vagrant@debian-dzdev:/tmp$ cd dev-domoticz/
vagrant@debian-dzdev:/tmp/dev-domoticz$ ls -la appversion.h
ls: cannot access 'appversion.h': No such file or directory
vagrant@debian-dzdev:/tmp/dev-domoticz$ cmake -DCMAKE_BUILD_TYPE=Release --log-level=ERROR CMakeLists.txt
Submodule 'extern/fmtlib' (https://github.com/fmtlib/fmt.git) registered for path 'extern/fmtlib'
Submodule 'extern/jsoncpp' (https://github.com/domoticz/jsoncpp) registered for path 'extern/jsoncpp'
Submodule 'minizip' (https://github.com/domoticz/minizip.git) registered for path 'extern/minizip'
Submodule 'extern/mosquitto' (https://github.com/eclipse/mosquitto.git) registered for path 'extern/mosquitto'
Submodule 'extern/sqlite-amalgamation' (https://github.com/azadkuh/sqlite-amalgamation.git) registered for path 'extern/sqlite-amalgamation'
Cloning into '/tmp/dev-domoticz/extern/fmtlib'...
Cloning into '/tmp/dev-domoticz/extern/jsoncpp'...
Cloning into '/tmp/dev-domoticz/extern/minizip'...
Cloning into '/tmp/dev-domoticz/extern/mosquitto'...
Cloning into '/tmp/dev-domoticz/extern/sqlite-amalgamation'...
Submodule path 'extern/fmtlib': checked out 'b0c8263cb26ea178d3a5df1b984e1a61ef578950'
Submodule path 'extern/jsoncpp': checked out '2a6e163b02ac5044d74a44ed15f8aa7af687aea5'
Submodule path 'extern/minizip': checked out '78eb93e8e0ba228f37b197d2022d66b73856c9ff'
Submodule path 'extern/mosquitto': checked out 'a8448a9c7b14bdaee6ec80419d43fd6544e789b6'
Submodule path 'extern/sqlite-amalgamation': checked out '15d0ff10ebc7e7225eced1de84bb52137000899b'
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/dev-domoticz
vagrant@debian-dzdev:/tmp/dev-domoticz$ make
Scanning dependencies of target revisiontag
-- Found Git: /usr/bin/git (found version "2.30.2")
[ 0%] Built target revisiontag
Scanning dependencies of target minizip
[ 0%] Building C object extern/minizip/CMakeFiles/minizip.dir/ioapi.c.o
[ 1%] Building C object extern/minizip/CMakeFiles/minizip.dir/unzip.c.o
[ 1%] Building C object extern/minizip/CMakeFiles/minizip.dir/zip.c.o
... <stripped> ...
-rw-r--r-- 1 vagrant vagrant 80 Dec 2 10:12 appversion.h
meal
I have fixed the issue and successfully built the 2022.2 domoticz version from sources.
The process starts by building first "domoticztester" and then "domoticz" as shown in the make.log file.
[ 1%] Built target minizip
[ 2%] Built target jsoncpp_static
[ 16%] Built target libmosquitto_static
[ 16%] Building CXX object CMakeFiles/domoticztester.dir/main/domoticz_tester.cpp.o
[ 16%] Building CXX object CMakeFiles/domoticztester.dir/main/BaroForecastCalculator.cpp.o
[ 17%] Building CXX object CMakeFiles/domoticztester.dir/main/HTMLSanitizer.cpp.o
[ 17%] Building CXX object CMakeFiles/domoticztester.dir/main/localtime_r.cpp.o
[ 17%] Building CXX object CMakeFiles/domoticztester.dir/main/SunRiseSet.cpp.o
[ 17%] Building CXX object CMakeFiles/domoticztester.dir/main/TrendCalculator.cpp.o
[ 17%] Building CXX object CMakeFiles/domoticztester.dir/main/WindCalculation.cpp.o
[ 19%] Building CXX object CMakeFiles/domoticztester.dir/main/json_helper.cpp.o
[ 19%] Building CXX object CMakeFiles/domoticztester.dir/hardware/ColorSwitch.cpp.o
[ 19%] Linking CXX executable domoticztester
[ 20%] Built target domoticztester
-- Found Git: /usr/bin/git (found version "2.20.1")
[ 20%] Built target revisiontag
Scanning dependencies of target domoticz
[ 20%] Building CXX object CMakeFiles/domoticz.dir/cmake_pch.hxx.gch
[ 20%] Building CXX object CMakeFiles/domoticz.dir/main/stdafx.cpp.o
[ 20%] Building CXX object CMakeFiles/domoticz.dir/main/BaroForecastCalculator.cpp.o
[ 20%] Building CXX object CMakeFiles/domoticz.dir/main/CmdLine.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/Camera.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/domoticz.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/dzVents.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/EventSystem.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/EventsPythonModule.cpp.o
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/EventsPythonDevice.cpp.o
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/Helper.cpp.o
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/HTMLSanitizer.cpp.o
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/IFTTT.cpp.o
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/json_helper.cpp.o
[ 25%] Building CXX object CMakeFiles/domoticz.dir/main/localtime_r.cpp.o
The file "appversion.h" is missing after "git clone https://github.com/domoticz/domoticz.git dev-domoticz"
and is required to build domoticztester. As consequence the following error is raised:
To solve the issue I created a "appversion.h" file in dev-domoticz directory with the content of previous version of appversion.h (2022.1).
Then launched the make process with the following steps:
- domoticztester is build successfully:
- target revisiontag created the new appversion.h file with the following content
#define APPVERSION 14787
#define APPHASH "d5d30c071"
#define APPDATE 1669890514
- Domoticz is built successfully.
BR
BR
meal
ferrosk
If you read my previous posts you should understand the file is generated automatically. You should not create it manually (you cannot just guess its content). Maybe you missed some step or previous step did not complete successfully and you didn't notice...
- kiddigital
Hi @meal and @ferrosk,
Thank you for looking into this.
I created Pull Request 5441 to fix the problem.
- kiddigital
Great, so it works for you now as well?
If so, please mark this thread as solved
