python-miio sh script did not execute in domoticz / SOLVED
d3smo
Post by d3smo »
I've install python-miio on my domoticz RPi i've get the token and everything. I've create a sh script mirobotStart.sh like that
#!/bin/bash
miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 5061---------------------366f start
and when i execute the script from ssh terminal with ./mirobotStart.sh it works, my vaccum robot start
I've then create a dummy switch in domoticz and on "Action On:" i fill the following command
script:///home/pi/domoticz/scripts/Xiaomi/mirobotStart.sh
When i activate the dummy switch the log told me that
2022-11-30 18:44:05.371 Status: User: Admin (IP: 192.168.1.18) initiated a switch command (356/Xiaomi Robot/On)
2022-11-30 18:44:05.596 Status: Executing script: /home/pi/domoticz/scripts/Xiaomi/mirobotStart.sh
2022-11-30 18:44:05.614 Error: Error executing script command (/home/pi/domoticz/scripts/Xiaomi/mirobotStart.sh). returned: 32512
I've made a chmod+X on the script and the right are the followings
-rwxrwxrwx  1 pi pi  153 Nov 30 16:00 mirobotStart.sh
Is there anyone to help me on that ?
Domoticz version: 2025.1
Re: python-miio sh script did not execute in domoticz
Domoticz probably runs with elevated rights so to test you should run the test script with sudo and see what the error is.
d3smo
Post by d3smo »
Thx for you reply, i begin to understand the script works only if i launch it as pi user, and as domoticz launch the scripts as root user it did not work. How can i found a turnaround ?
Solve the problem why it is not running as root.
You probably have to enter the full path to miiocli in the bash script eg /home/pi/miiocli
ferrosk
Domoticz version: 2023.2
Post by ferrosk »
if domoticz is running as root and you need execute the command as 'pi' user you can try modify the script:
#!/bin/bash
sudo -u pi miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 5061---------------------366f start
Domoticz 2023.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
d3smo
Post by d3smo »
Thx for the help, it's not solve but we are approching, to figure out what the error was i connect to ssh as root and execute the script to check the errors
So with the first solution exec it as pi user he is the error
root@domoticzPi3:/home/pi# sudo -u pi miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 50---------------------------6366f start
sudo: miiocli: command not found
And with the path en other error, it seems another process need also the path
root@domoticzPi3:/home/pi# /home/pi/.local/bin/miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 50615857436c4e4f795971576166366f start &
[1] 1128
root@domoticzPi3:/home/pi# Traceback (most recent call last):
  File "/home/pi/.local/bin/miiocli", line 5, in <module>
    from miio.cli import create_cli
ModuleNotFoundError: No module named 'miio'
^C
[1]+  Exit 1                  /home/pi/.local/bin/miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 50--------------------------66f start
d3smo
Post by d3smo »
IT WORKS solution 1 + 2 works !
root@domoticzPi3:/home/pi# sudo -u pi /home/pi/.local/bin/miiocli roborockvacuum --model rockrobo.vacuum.v1 --ip 192.168.1.32 --token 506------------------------6f start
Thx guys
