Script to estimate energy flow on the meter
Posted: Sunday 20 November 2022 21:43
by thebenchmark
Hello everyone
I measure both my power usage & production. After the usage meter there is no production it has been completely split.
There are 5 solar generators and 1 usage meters in total. They are all connected to DomoticZ and date is nicely being processed there.
I wanted to add a virtual meter to determine the power movement at the meter level. This can be calculated as usage minus production.
I made script for this but its not calculating. I'm ashamed to say I had it working before but now it's no longer working after adding the 5th solar array.
I'm running the latest stable domoticZ version.
	    timer = { 'every minute' }
	    local pcmPower = domoticz.devices(9)      -- Internal power consumption meter
	    local pvzPower = domoticz.devices(3)      -- solar zuid
	    local pvoPower = domoticz.devices(4)      -- solar oost
	    local pvwPower = domoticz.devices(5)      -- solar west
	    local pvvPower = domoticz.devices(2)      -- solar front
	    local pvz2Power = domoticz.devices(1)      -- solar zuid APS 2
	    local totalPower = domoticz.devices(6)  -- total (power consumtion - solar) power meter for movement of MAIN grid
	    totalPower.updateElectricity(
            	pcmPower.WhActual - pvzPower.WhActual - pvoPower.WhActual - pvwPower.WhActual - pvz2Power.WhActual - pvvPower.WhActual,
            	pcmPower.WhTotal - pvzPower.WhTotal - pvoPower.WhTotal - pvwPower.WhTotal - pvz2Power.WhTotal - pvvPower.WhTotal
EDIT: After a bit of searching it seems the new power meter doesn't support the "WhActual" value. Its a youless meter so i'll have to find that.
Re: Script to estimate energy flow on the meter
Posted: Sunday 20 November 2022 22:14
by HvdW
Here you go. viewtopic.php?p=293865#p293865
The script in itself is not your usercase buy you can learn from this script how to import the JSON string and extract the data you'd like to analyze.
