set switch state by parameter dzvents
kispalsz
Post by kispalsz »
Hi!
How can I change my switch state by parameter?
I have a swhitch device, but cannot change there state.
This work:
Text device: domoticz.devices("Time stamp error history entry 1").updateText(item.json["6800"].value)
Temperature device: domoticz.devices('Boiler temp actual value').updateTemperature(tonumber(item.json["8310"].value))
Counter device: domoticz.devices("Fan speed").updateCounter(item.json["8323"].value)
domotic.devices("XYZ) .updateText .updateTemperature and .updateCounter are working. But what is doing with virtualswitch ?
I found only .switchOn and switchOff and .toggleSwitch function. But how can I set my switch state by parameter? ( without if function)
Thanks.
willemd
Re: set switch state by parameter dzvents
Post by willemd »
I have not tried it but the dzvents wiki page states:
There are many switch-like devices. Not all methods are applicable for all switch-like devices. You can always use the generic setState(newState) method.
kispalsz
Post by kispalsz »
Hi!
Thanks! This was a solution.
What subtype of virtual switch are you using? There are many.https://www.domoticz.com/wiki/Dummy_for ... h_Subtypes
Each switch type has specific dzvents switch options next to the general ones.
