Checking a sensor every few seconds
Posted: Monday 14 November 2022 22:21
I want to check my fridge door using rxfcom and a door switch. The door switches normally work fine but if the fridge door is closed quickly then the closed signal is missed.
So I looked at this thread for inspiration. viewtopic.php?t=36400
Thanks for that.
My mods look like this.
and I'm getting these error messages.
2022-11-14 22:16:00.650 Error: dzVents: Error: (3.1.8) every10Seconds: An error occurred when calling event handler Script #1try-fridge-door
2022-11-14 22:16:00.650 Error: dzVents: Error: (3.1.8) every10Seconds: ...s/dzVents/generated_scripts/Script #1try-fridge-door.lua:42: attempt to index a nil value (global 'domoticz')
It's late, I'm tired, yes and I've had a few glasses of wine too. Please can anyone tell me what I'm missing here.
Thanks for that.
local scriptVar = 'every10Seconds'
return
on =
timer =
'every minute',
customEvents =
scriptVar,
logging =
level = domoticz.LOG_ERROR,
marker = scriptVar,
execute = function( dz, item )
if dz.devices('Fridge Door_D3').state == 'Off' then return end -- If fridge door check device state is Off the script will not do anything,
if item.isTimer then
for delay = 10, 50, 10 do
dz.emitEvent(scriptVar).afterSec(delay)
local fridgedoor = dz.devices('Fridge Door_D3')
local function setvar(var, to)
if var.value ~= to and dz.startTime.secondsAgo > 60 then var.set(to) end
if fridgedoor.lastUpdate.secondsAgo > 60 then
domoticz.log('Fridge Door switch >x seconds')
msg="Fridge Door Open " .. fridgedoor.lastUpdate.minutesAgo .. " mins/seconds"
domoticz.openURL('https://api.telegram.org/botxxxxxxxxxxxxxxxxxxxxxxxx/sendMessage?chat_id=xxxxxxx&text=' .. msg)
domoticz.log('Fridge Door closed')
