Stop a device if power too low
Posted: Wednesday 09 November 2022 10:03
by Patricen
I'm trying to set-up a script that would stop a device if the power consumption is below a minimum level for a few minutes (practically, I want to switch off the smart plug if the devices that are connected to it are in standby mode).
I'm trying to implement this using dzVents but no success as I do have issues extracting the actual power from the device (Zwave plug NAS-WR01Z Power plug 12A+).
Any clue?
return
    on =
        devices =
            'Bureau-kWh Meter',
    timer = {'Every 10 seconds'},
    --data =
    --    lastupdated-- =
        --    initial = 0,
    logging =
        level = domoticz.LOG_DEBUG, --LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
        marker = 'Bureau-kWh Meter',
    execute = function(dz, item)
        local Time = require('Time')
        local pwr = dz.devices('Bureau-kWh Meter').actualWatt
        local lowp
        local seuil = 8
        local lastupdated = Time
        if pwr > seuil then
			    dz.log('=========================consommation utilisation')
			    lowp = 0
			    lastupdated = Time(dz.time)
			    dz.log('=========================consommation utilisation' .. lastupdated)
                    -- on s'arrĂȘte lĂ
            --return
        if pwr < seuil  then
                dz.log('=========================basse consommation')
                if lowp == 1 then
                lowp = l
                dz.log('=========================basse consommation' .. lastupdated)
                return
Re: Stop a device if power too low
Posted: Wednesday 09 November 2022 12:31
So what is exactly your problem?
Do you get an error? Is the value pwr empty?
Is your device supporting the actualWatt function?
Posted: Thursday 10 November 2022 6:34
by Patricen
Below is the log. 700 is the id of the device, I've no idea if it supports actualWatt function, but for sure there is a power feedback on Domoticz control panel.
2022-11-10 06:29:23.079 Status: dzVents: Info: Bureau-kWh Meter: ------ Start internal script: Stop bureau: Device: "Bureau-kWh Meter (OpenZWave)", Index: 700
2022-11-10 06:29:23.080 Status: dzVents: Info: Bureau-kWh Meter: =========================consommation utilisation
2022-11-10 06:29:23.080 Status: dzVents: Info: Bureau-kWh Meter: ------ Finished Stop bureau
2022-11-10 06:29:23.080 Error: dzVents: Error: (3.1.8) Bureau-kWh Meter: An error occurred when calling event handler Stop bureau
2022-11-10 06:29:23.080 Error: dzVents: Error: (3.1.8) Bureau-kWh Meter: /home/pi/domoticz/dzVents/runtime/Time.lua:28: bad argument #1 to 'match' (string expected, got table)
Posted: Thursday 10 November 2022 22:27
Read the docs about using time
https://www.domoticz.com/wiki/DzVents:_ ... ime_object
I think line
should be
local lastupdated = Time()
Posted: Saturday 12 November 2022 0:13
by HvdW
Maybe this post viewtopic.php?p=293865#p293865 is helpful for you.
If you have any questions: ask
Posted: Monday 14 November 2022 18:59
by Patricen
waltervl wrote: Wednesday 09 November 2022 12:31 So what is exactly your problem?
Do you have any idea about the way to find if a device supports actualWatt, or any other function?
Posted: Tuesday 15 November 2022 0:27
Find the device type in the device widget and then look the device up in the DzVents documentation.
Also check the wiki with device examples https://www.domoticz.com/wiki/Dummy_for ... counter.29
Posted: Tuesday 15 November 2022 14:01
by Patricen
waltervl wrote: Tuesday 15 November 2022 0:27 Find the device type in the device widget and then look the device up in the DzVents documentation.
Ok it looks like the issue is related to
local pwr = dz.devices('Bureau-kWh Meter').WhActual
that leads to the following error : Error: dzVents: Error: (3.1.8) Bureau-kWh Meter: /home/pi/domoticz/dzVents/runtime/Time.lua:28: bad argument #1 to 'match' (string expected, got table)
as
dz.log('WhActual ' .. dz.devices('Bureau-kWh Meter').WhActual .. ' W')
gives the following log Status: dzVents: Info: Bureau-kWh Meter: WhActual 46.12 W
If I can go over the mismatch between string and table -that I do need help for-, I do figure out that there will be an issue afterwards when comparing a string to an integer, but this will be another story...
Posted: Wednesday 16 November 2022 16:19
From the dzVents documentation
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Electric usage
actualWatt: Number. Current Watt usage.
WhActual: Number. Current Watt usage. (please use actualWatt)
So what if you use
Posted: Wednesday 16 November 2022 16:34
Additional, do you have more devices named 'Bureau-kWh Meter' as DzVents cannot handle multiple device with the same name. Device names should be unique!
Posted: Thursday 17 November 2022 18:59
by Patricen
waltervl wrote: Wednesday 16 November 2022 16:34 Additional, do you have more devices named 'Bureau-kWh Meter' as DzVents cannot handle multiple device with the same name. Device names should be unique!
No, this is the only one
Posted: Thursday 17 November 2022 19:50
Did you try .actualWatt instead of .WhActual as advised by the documentation?
Posted: Saturday 19 November 2022 18:30
by Patricen
Hello, yes, I tried, and I finally found out that the issue is coming from the pretty tricky time functions.
The issue is now clearer and I need to have power below x Watts for a "certain time" that I'm not able to code...
