blockly 'flipflopping'
Posted: Tuesday 08 November 2022 19:26
I have a nameless 433mhz physical switch from an earlier house. It has 3 buttons: one with a on/off sign, one up and one down.
This is recognised in Domoticz: the on/off sends on or off alternating, the other buttons send only 'on'.
I focus on the on/off button here.
I want to use that button to toggle a 433Mhz switched light, using blockly. I have tried several setups, but it keeps on 'flipflopping' between on and off stages untill I disable this script. I cannot see what I do wrong , can someone please help me out? (If this setup is completely wrong thinking, that's fine too. Any help is good.)
NB: I'm not into LUA or dzvents, that;s why I hope to achieve this in blockly.
NB: "sleutelhanger" is the physical switch on which I push the button, "boekenkast" is the light that needs to be turned off and on.
