Need to know if i'm in the night time or not
pipiche
Post by pipiche »
I have found on the forum the idea to create a nighTime dzVents device. But I'm failing to make it working.
For sure I'm doing something wrong, but cannot find it
cat test_nightTime.lua
local SCRIPT_NAME = 'testing_NightTime'
    active = true,
	timer = { 'every minute' },
        devices = {
		['nightTime'] = {'between 22:31 and 07:59'},
    logging =
        level = domoticz.LOG_INFO,  -- change to LOG_ERROR when all OK
        marker = SCRIPT_NAME,
    execute = function(domoticz, nightTime, item, timer)
	local time_window = domoticz.devices( 'nightTime' ).state
    	domoticz.log('system: '..domoticz.time.rawTime)
    	domoticz.log('Domoticz: '..domoticz.settings.domoticzVersion)
    	domoticz.log('domoticzvents: '..domoticz.settings.dzVentsVersion)
    	domoticz.log( ' --------the trigger---------' )
    	domoticz.log(item.name .. ' seconds ago ' ..item.lastUpdate.raw )
    	domoticz.log( ' nightTime ' ..time_window )
Nov 06 17:57:00 pi3 domoticz[17721]: 2022-11-06 17:57:00.417 Status: dzVents: Info: testing_NightTime: ------ Start external script: test_nightTime.lua:, trigger: "every minute"
Nov 06 17:57:00 pi3 domoticz[17721]: 2022-11-06 17:57:00.418 Error: dzVents: Error: (3.1.8) testing_NightTime: There is no device with that name or id: nightTime
Nov 06 17:57:00 pi3 domoticz[17721]: 2022-11-06 17:57:00.419 Error: dzVents: Error: (3.1.8) testing_NightTime: An error occurred when calling event handler test_nightTime
Nov 06 17:57:00 pi3 domoticz[17721]: 2022-11-06 17:57:00.419 Error: dzVents: Error: (3.1.8) testing_NightTime: /var/lib/domoticz/scripts/dzVents/scripts/test_nightTime.lua:19: attempt to index a nil value
boum
Domoticz version: 4.10717
Re: Need to know if i'm in the night time or not
Post by boum »
There is no switch called nightTime, or there are several devices with that name and dzVents handles that badly.
If you want to test for night time in dzVent, just use the time property:
	execute = function(dz, item)
		if dz.time.isNightTime then
		  -- do stuff only at night
Otherwise you must first create your device using the virtual hardware.
In your dzVents triggers, no need to add the device as trigger as nobody should change it. But then, you can also reset it to the correct value. But no point in putting a time interval.
    active = true,
        devices = { 'nightTime' },
    logging =
	local device = domoticz.devices( 'nightTime' )
	if domoticz.time.isNightTime then
                device.switchOn().checkFirst()
                device.switchOff().checkFirst()
pipiche
Post by pipiche »
in fact I was looking to define my own might time window. So probably I'll have to end up with testing the current time.
boum
Post by boum »
This can be done easily too. You still need to create your virtual switch named nightTime (and have only 1 device with this name)
local DUSK_TIME = 'at 22:31'
local DAWN_TIME = 'at 7:58'
    active = true,
	timer = { DUSK_TIME, DAWN_TIME },
    logging =
	if item.trigger == DUSK_TIME then
	elseif item.trigger == DAWN_TIME then
            	domoticz.log('Unknown trigger for nighTime ', domoticz.LOG_ERROR)
then, in your other scripts, you can test for:
domoticz.devices('nightTime').active
