RGBWW light recognized as RGBWZ light
Posted: Saturday 05 November 2022 13:16
by Gravityz
i am trying to integrate an RGBWW light through MQTT auto discovery.
this config seems to work in Home assistant but when i use this in domoticz it recognises the light as RGBWZ
can anybody see what is wrong with this config (eg what needs to be changed to fix it for domoticz)
it is an LSC(Tuya) RGBWW light running OpenBK firmware
so either the MQTT functionality between HA and Domoticz is not the same(it should be) or there is a bug in MQTT autodiscovery on the domoticz site.
mqtt:
  light:
  - unique_id: "OpenBK7231T_06ECB4BF_light"
    rgb_command_template: "{{ '#%02x%02x%02x0000' | format(red, green, blue)}}"
    rgb_value_template: "{{ value[0:2]|int(base=16) }},{{ value[2:4]|int(base=16) }},{{ value[4:6]|int(base=16) }}"
    rgb_state_topic: "Douchelamp/led_basecolor_rgb/get"
    rgb_command_topic: "cmnd/Douchelamp/led_basecolor_rgb"
    command_topic: "cmnd/Douchelamp/led_enableAll"
    state_topic: "Douchelamp/led_enableAll/get"
    availability_topic: "Douchelamp/connected"
    payload_on: 1
    payload_off: 0
    brightness_command_topic: "cmnd/Douchelamp/led_dimmer"
    brightness_scale: 100
    #brightness_value_template: "{{ value }}"
    color_temp_command_topic: "cmnd/Douchelamp/led_temperature"
    color_temp_state_topic: "Douchelamp/led_temperature/get"
    #color_temp_value_template: "{{ value }}"
