Energie-Usage last year
SlaXeon
Post by SlaXeon »
Dear all,
I have a problem and maybe someone can help me.
local httpResponses = "energyYearTotal"
timer = { "at 15:13" },
httpResponses = { "setSolarInVar1y" }
logging = {
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when script works as expected
marker = "setSolarInVar1y" },
execute = function(dz, item)
-- ****************************** Your settings below this line ***************************************************
usageDevice = dz.devices(255) -- Replace xxxx with ID of energyDevice you want to track
yearTotal = dz.devices(319) -- Create as virtual managed counter (energy) and change yyyy to the ID of the new device
-- ****************************** No changes required below this line *********************************************
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function triggerJSON(idx, period, delay)
local URLString = "http://192.168.10.47:8080" .. "/json.htm?type=graph&sensor=counter&range=" .. period .. "&idx=" .. usageDevice.idx
dz.openURL({ url = URLString,
method = "GET",
callback = "setSolarInVar1y" })
local function calculateYearTotal(rt)
local yearTotal = 0
local currentYear = dz.time.rawDate:sub(1,4)
for i=1,#rt do
--if rt[id].d:sub(1,4) == currentYear then
logWrite(rt.d .. " ==>> " .. rt.u_max)
yearTotal = yearTotal + rt.u_max
--end
return yearTotal / 1000
if not item.isHTTPResponse then
triggerJSON(usageDevice.idx, "year")
elseif item.ok then -- statusCode == 2xx
yearTotal.update(0,calculateYearTotal(item.json.result))
logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")" ,dz.LOG_ERROR)
logWrite(item.data)
I am using the code above to calculate the total power consumption for the last year. When I am calling the URL manually in the browser, I get 365 items as expected from the URL, but unfortunately when Domoticz itself is running the URL I get only 97,98 or 99 item (this is random changing).
Has someone an Idea how to enlarge the amount of items I will get back from Domotizc. Maybe I can add something to the URL to give the feedback some more time for running.
Enjoy your Day
Best regards
Daniel
Re: Energie-Usage last year
to debug you can log the URLString variable to see if it differs from the manual entered URL.
Edit: could also be that the 365 items list has a incorrect character that cause to shorten the list in DzVents translation from json to table.
SlaXeon
Post by SlaXeon »
thank you for the reply.
I have debug the URL and everything seems good. The problem is, that the Amout of Items I get back is randomly changing, sometime 97 items, sometime 98 or 99 items. I have checked the list and this is correct. I can only believe, that the timing wrong.
Best regards
Daniel
jvdz
Domoticz version: 4.107
Post by jvdz »
I am not a expert in DzVents, just use basic LUA myself, but shouldn't this it bit :
			logWrite(item.data)
look like this:?
		if item.isTimer then
			logWrite(item.data)
To avoid multiple triggers and log errors when they occur?
EDIT:Is the u_max field always there in each record? I don't think i have any Energy device that contains that field so can't check.
When it isn't always present you could try changing these lines to avoid any hard LUA NIL errors to:
				logWrite(rt.d .. " ==>> " .. (rt.u_max or 0))
				yearTotal = yearTotal + (rt.u_max or 0)
SlaXeon
Post by SlaXeon »
unfortunately each value has a u_max position and with isTimer the script is not working any more :(
Thank you for trying to help me, but the tips do not work :(
jvdz
Post by jvdz »
Think that it should fire at the time defined in: timer = { "at 15:13" },
That is how the example looks in the Wiki.
