Hi!
Next scenario:
I am having domoticz up and running in a scouting building. Than a crash happened. Impossible to boot the pi.
At home I reinstalled another SD card with only using domoticz. I copied an older database and tried to start Domoticz but it fails to start.
What can I do? Originally I used a number of hardware devices which are not available at home. Might lack of these holds domoticz to start?
TIA
-Bart
how to install database after crash
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Re: how to install database after crash
update:
I did a database restore via settingsmenu Than after a while the original dashboard popped up for a few seconds. Than the message that no devices where yet there. The solution was to restart the pi and logged into Domoticz with original credentials.
So problem seems to be solved.
-Bart
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
