lua to dzvents convert
Posted: Tuesday 25 October 2022 19:34
by ilkaskim
Hello, I have a script that doesn't work anymore. To be honest, I don't really plan on programming either. It just doesn't trigger anymore since August 25th. Could someone see if this script can also be converted to dzvents and how this code works again?
t1 = os.time()
s = otherdevices_lastupdate['Ventilator']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if devicechanged['Werkstatt_Humidity'] ~= nil then
print("luftfeuchtigkeit in Werkstatt ist: " .. devicechanged['Werkstatt_Humidity'] .. " %" .. " - Ventilator Temp. ist: " .. otherdevices['Ventilator'] .. " °C")
if (devicechanged['Werkstatt_Humidity'] >= 75) then
if (otherdevices['Ventilator'] == 'Off' and difference > 3600) then
print("Luftfeuchtigkeit in Werkstatt ist über 80%, schalte Ventilator ein. ")
commandArray['Ventilator']='On FOR 10'
Re: lua to dzvents convert
Posted: Friday 28 October 2022 9:09
by jannl
How do you know the script is not triggered?
Did you test with a print statement before the if?
What is the exact name of the script?
Posted: Friday 28 October 2022 12:03
by plugge
Assuming that your Ventilator has a temp sensor, and you want to test the humidity every hour (3600 secs), you could try this script (Not tested!)
local scriptVar = 'Werkstatt Hum'
devices = {},
timer = {'every hour', -- check every hour
logging = {
level = domoticz.LOG_DEBUG,
marker = scriptVar
execute = function(dz, item)
local fantime = 10 -- duration in minutes that the fan is on
local fan = dz.devices('Ventilator')
local hum = dz.devices('Werkstatt_Humidity').humidity
print(scriptVar..": Momentane Luftfeuchtigkeit in Werkstatt ist: " .. hum .. " %" .. " - Ventilator Temp. ist: " .. fan.temp .. " °C")
if hum >= 75 and
fan.state == 'Off'
then
print('Ventilator eingeschaltet fuer '..fantime..' minuten')
fan.switchOn().forMin(fantime)
print(scriptVar..' Humidity = '..hum..' % '..' fan switch is '..fan.state)
Posted: Friday 28 October 2022 18:29
by ilkaskim
jannl wrote: Friday 28 October 2022 9:09
Hello, thanks for the reply. My fan is a switch with no humidity meter. I take the moisture from a BME280. Since my workshop has no heating, I wanted to achieve circulating air, which has worked so far. The name of the switch is "Ventilator" and the name of the BME280 is "Workshop_Humidity".
I get the status message: 2022-10-28 18:23:45.823 Status: LUA: luftfeuchtigkeit in Werkstatt ist: 85.0 % - Ventilator Temp. ist: 17.4 °C
I have already tried different values when the fan should be switched on but so far it has not worked. It's funny that it worked earlier and I don't get an error message either.
As soon as the humidity was reached, I got a message that the fan was switched on in the log
Posted: Friday 28 October 2022 18:32
by ilkaskim
plugge wrote: Friday 28 October 2022 12:03
Thanks for the feedback. I will try it and report
An error message appears.
The name fan actually appears twice. Once as a switch and once as a 1-Wire Temp sensor.
2022-10-28 18:49:00.484 Error: dzVents: Error: (3.1.8) Werkstatt Hum: Multiple items found for Ventilator (device). Please make sure your names are unique or use ids instead.
2022-10-28 18:49:00.499 Error: dzVents: Error: (3.1.8) Werkstatt Hum: An error occurred when calling event handler Script #3
2022-10-28 18:49:00.499 Error: dzVents: Error: (3.1.8) Werkstatt Hum: ...domoticz/scripts/dzVents/generated_scripts/Script #3.lua:17: attempt to concatenate a nil value (field 'temp')
Re: lua to dzvents convert [Solved]
Posted: Saturday 29 October 2022 1:40
by plugge
ilkaskim wrote: Friday 28 October 2022 18:32
Correct, that is because you use the device labelled 'Ventilator' both as a switch and as a temperature sensor in your script, which should not be done.
Besides, why do you need a temperature reading when you only check the humidity?
Here's the corrected script:
devices = {},
logging = {
marker = scriptVar
print(scriptVar..": Momentane Luftfeuchtigkeit in Werkstatt ist: " .. hum .. " %")
if hum >= 75 and
fan.state == 'Off'
then
print(scriptVar..' Humidity = '..hum..' % '..' and fan switch is '..fan.state)
Posted: Saturday 29 October 2022 15:07
by ilkaskim
you're right. the temperature measurement was actually a gimmick. your script works. Many Thanks
Posted: Saturday 29 October 2022 15:34
by plugge
@ilkaskim Gern geschehen. Glad I could help.
