STARKVIND Domoticz to Zigbee2MQTT
BazemanKM
Post by BazemanKM »
STARKVIND air purifier works with Zigbee2MQTT. https://www.zigbee2mqtt.io/devices/E200 ... ikea-e2007
To change the mode publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"fan_mode": VALUE} where VALUE can be: off, auto, 1, 2, 3, 4, 5, 6, 7, 8, 9.
Autodiscovery MQTT doesn't make a selector switch for the fan mode, so i made a dummy (idx 541). 0 = off, 10 = auto, 20 =1 till 9 = 100
From Domoticz in MQTT:
    "Battery" : 255,
    "LastUpdate" : "2022-10-24 10:39:30",
    "LevelActions" : "||||||||||",
    "LevelNames" : "Uit|Auto|1|2|3|4|5|6|7|8|9",
    "LevelOffHidden" : "false",
    "RSSI" : 12,
    "SelectorStyle" : "1",
    "description" : "",
    "dtype" : "Light/Switch",
    "hwid" : "16",
    "id" : "0001426D",
    "idx" : 541,
    "name" : "Luchtververser",
    "nvalue" : 2,
    "stype" : "Switch",
    "svalue1" : "100",
    "switchType" : "Selector",
    "unit" : 1
We have to work with svalue1, that's the fanmode.
I made a flow in Node-RED to translate Domoticz to MQTT
[{"id":"1bec2846.4029b8","type":"tab","label":"Luchtververser","disabled":false,"info":""},{"id":"92af5d9e.d6b11","type":"mqtt in","z":"1bec2846.4029b8","name":"Domoticz Luchtververser","topic":"domoticz/out/541/","qos":"2","datatype":"auto","broker":"4d2ff189.666908","nl":false,"rap":false,"x":150,"y":200,"wires":[["a6e7acbe.f6401"]]},{"id":"a6e7acbe.f6401","type":"json","z":"1bec2846.4029b8","name":"","property":"payload","action":"","pretty":false,"x":370,"y":200,"wires":[["b6d70fc0.f6db5"]]},{"id":"cb50b45d.9a4e28","type":"mqtt out","z":"1bec2846.4029b8","name":"MQTT Lucht ververser","topic":"zigbee2mqtt/Luchtververser/set/","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4d2ff189.666908","x":1060,"y":220,"wires":[]},{"id":"b6d70fc0.f6db5","type":"switch","z":"1bec2846.4029b8","name":"","property":"payload.svalue1","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"10","vt":"str"},{"t":"eq","v":"20","vt":"str"},{"t":"eq","v":"30","vt":"str"},{"t":"eq","v":"40","vt":"str"},{"t":"eq","v":"50","vt":"str"},{"t":"eq","v":"60","vt":"str"},{"t":"eq","v":"70","vt":"str"},{"t":"eq","v":"80","vt":"str"},{"t":"eq","v":"90","vt":"str"},{"t":"eq","v":"100","vt":"str"}],"checkall":"true","repair":false,"outputs":11,"x":530,"y":200,"wires":[["84ae7545.8ffa28"],["881d8691.c06168"],["19ce1141.d3d9ef"],["62faf9e6.ef52b8"],["5ff40353.feecbc"],["27c0f93.50b5306"],["76c5ca57.250ad4"],["dbddd75e.ec73d8"],["15badd72.2f72a3"],["b3344efa.f3137"],["a0d9040d.0eb0c8"]]},{"id":"881d8691.c06168","type":"function","z":"1bec2846.4029b8","name":"auto","func":"msg.payload = {\"fan_mode\": auto}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":60,"wires":[["cb50b45d.9a4e28"]]},{"id":"19ce1141.d3d9ef","type":"function","z":"1bec2846.4029b8","name":"1","func":"msg.payload = {\"fan_mode\": 1}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":100,"wires":[["cb50b45d.9a4e28"]]},{"id":"62faf9e6.ef52b8","type":"function","z":"1bec2846.4029b8","name":"2","func":"msg.payload = {\"fan_mode\": 2}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":140,"wires":[["cb50b45d.9a4e28"]]},{"id":"5ff40353.feecbc","type":"function","z":"1bec2846.4029b8","name":"3","func":"msg.payload = {\"fan_mode\": 3}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":180,"wires":[["cb50b45d.9a4e28"]]},{"id":"27c0f93.50b5306","type":"function","z":"1bec2846.4029b8","name":"4","func":"msg.payload = {\"fan_mode\": 4}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":220,"wires":[["cb50b45d.9a4e28"]]},{"id":"76c5ca57.250ad4","type":"function","z":"1bec2846.4029b8","name":"5","func":"msg.payload = {\"fan_mode\": 5}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":260,"wires":[["cb50b45d.9a4e28"]]},{"id":"dbddd75e.ec73d8","type":"function","z":"1bec2846.4029b8","name":"6","func":"msg.payload = {\"fan_mode\": 6}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":300,"wires":[["cb50b45d.9a4e28"]]},{"id":"15badd72.2f72a3","type":"function","z":"1bec2846.4029b8","name":"7","func":"msg.payload = {\"fan_mode\": 7}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":340,"wires":[["cb50b45d.9a4e28"]]},{"id":"b3344efa.f3137","type":"function","z":"1bec2846.4029b8","name":"8","func":"msg.payload = {\"fan_mode\": 8}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":380,"wires":[["cb50b45d.9a4e28"]]},{"id":"a0d9040d.0eb0c8","type":"function","z":"1bec2846.4029b8","name":"9","func":"msg.payload = {\"fan_mode\": 9}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":420,"wires":[["cb50b45d.9a4e28"]]},{"id":"8381b23d.4aaae","type":"comment","z":"1bec2846.4029b8","name":"","info":"","x":150,"y":60,"wires":[]},{"id":"84ae7545.8ffa28","type":"function","z":"1bec2846.4029b8","name":"off","func":"msg.payload = {\"fan_mode\": off}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":20,"wires":[[]]},{"id":"4d2ff189.666908","type":"mqtt-broker","name":"192.168.2.4","broker":"192.168.2.4","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"protocolVersion":"4","keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
The flow doesn't work, what is wrong?
Or is there a way to send a command from de Domoticz selector switch?
FireWizard
Re: STARKVIND Domoticz to Zigbee2MQTT
Post by FireWizard »
Hello @BazemanKM
I loaded your flow in my test system and indeed it gives directly 2 errors.
Remember, unlike 1, 2, 3, etc. off and auto are not numbers. It are strings! Does your fan accept this "value" as a string.
It is at least the value, we have to use, coming from the selector switch.
That is very simple, but you do not tell what works and what doesn't work.
It is always better to tell that, as the one, who might be able to help you, can focus on the things that do not work.
1. I see that you use as incoming topic in the MQTT node domoticz/out/$IDX. Did you configure Domoticz as such?
2. You can remove the JSON node, as you can set in the MQTT Input node the "Output" to "a parsed JSON object".
3. In the upper 2 "Function" nodes, marked "off" and "auto" the first line is not correct.
msg.payload = {"fan_mode": off}
return msg;
and
msg.payload = {"fan_mode": auto}
return msg;
Node Red (Javascript) interpreters this auto and off as a variable and so complains about:
"ReferenceError: off is not defined (line 1, col 28)"
or auto is not defined.
And that is correct. you did not define these two variables.
But probably, it are no variables but strings. So change the lines to:
msg.payload = {"fan_mode": "off"}
return msg;
and
msg.payload = {"fan_mode": "auto"}
return msg;
4. Assuming the your fan accepts strings, like "off" and "auto", does it also accept numbers? Or should the numbers be strings as well.
So not
msg.payload = {"fan_mode": 1}
return msg;
but
msg.payload = {"fan_mode": "1"}
return msg;
Test it and let us know.
BazemanKM
Post by BazemanKM »
SOLVED: Had to use "string" thanks FireWizard
[{"id":"1bec2846.4029b8","type":"tab","label":"Luchtververser","disabled":false,"info":""},{"id":"92af5d9e.d6b11","type":"mqtt in","z":"1bec2846.4029b8","name":"Domoticz Luchtververser","topic":"domoticz/out/541","qos":"2","datatype":"auto","broker":"4d2ff189.666908","nl":false,"rap":false,"x":150,"y":200,"wires":[["a6e7acbe.f6401"]]},{"id":"a6e7acbe.f6401","type":"json","z":"1bec2846.4029b8","name":"","property":"payload","action":"","pretty":false,"x":370,"y":200,"wires":[["b6d70fc0.f6db5"]]},{"id":"cb50b45d.9a4e28","type":"mqtt out","z":"1bec2846.4029b8","name":"MQTT Lucht ververser","topic":"zigbee2mqtt/Luchtververser/set","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4d2ff189.666908","x":1060,"y":220,"wires":[]},{"id":"b6d70fc0.f6db5","type":"switch","z":"1bec2846.4029b8","name":"","property":"payload.svalue1","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"10","vt":"str"},{"t":"eq","v":"20","vt":"str"},{"t":"eq","v":"30","vt":"str"},{"t":"eq","v":"40","vt":"str"},{"t":"eq","v":"50","vt":"str"},{"t":"eq","v":"60","vt":"str"},{"t":"eq","v":"70","vt":"str"},{"t":"eq","v":"80","vt":"str"},{"t":"eq","v":"90","vt":"str"},{"t":"eq","v":"100","vt":"str"}],"checkall":"true","repair":false,"outputs":11,"x":530,"y":200,"wires":[["84ae7545.8ffa28"],["881d8691.c06168"],["19ce1141.d3d9ef"],["62faf9e6.ef52b8"],["5ff40353.feecbc"],["27c0f93.50b5306"],["76c5ca57.250ad4"],["dbddd75e.ec73d8"],["15badd72.2f72a3"],["b3344efa.f3137"],["a0d9040d.0eb0c8"]]},{"id":"881d8691.c06168","type":"function","z":"1bec2846.4029b8","name":"auto","func":"msg.payload = {\"fan_mode\": \"auto\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":60,"wires":[["cb50b45d.9a4e28"]]},{"id":"19ce1141.d3d9ef","type":"function","z":"1bec2846.4029b8","name":"1","func":"msg.payload = {\"fan_mode\": \"1\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":100,"wires":[["cb50b45d.9a4e28"]]},{"id":"62faf9e6.ef52b8","type":"function","z":"1bec2846.4029b8","name":"2","func":"msg.payload = {\"fan_mode\": \"2\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":140,"wires":[["cb50b45d.9a4e28"]]},{"id":"5ff40353.feecbc","type":"function","z":"1bec2846.4029b8","name":"3","func":"msg.payload = {\"fan_mode\": \"3\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":180,"wires":[["cb50b45d.9a4e28"]]},{"id":"27c0f93.50b5306","type":"function","z":"1bec2846.4029b8","name":"4","func":"msg.payload = {\"fan_mode\": \"4\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":220,"wires":[["cb50b45d.9a4e28"]]},{"id":"76c5ca57.250ad4","type":"function","z":"1bec2846.4029b8","name":"5","func":"msg.payload = {\"fan_mode\": \"5\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":260,"wires":[["cb50b45d.9a4e28"]]},{"id":"dbddd75e.ec73d8","type":"function","z":"1bec2846.4029b8","name":"6","func":"msg.payload = {\"fan_mode\": \"6\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":300,"wires":[["cb50b45d.9a4e28"]]},{"id":"15badd72.2f72a3","type":"function","z":"1bec2846.4029b8","name":"7","func":"msg.payload = {\"fan_mode\": \"7\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":340,"wires":[["cb50b45d.9a4e28"]]},{"id":"b3344efa.f3137","type":"function","z":"1bec2846.4029b8","name":"8","func":"msg.payload = {\"fan_mode\": \"8\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":380,"wires":[["cb50b45d.9a4e28"]]},{"id":"a0d9040d.0eb0c8","type":"function","z":"1bec2846.4029b8","name":"9","func":"msg.payload = {\"fan_mode\": \"9\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":420,"wires":[["cb50b45d.9a4e28"]]},{"id":"8381b23d.4aaae","type":"comment","z":"1bec2846.4029b8","name":"https://www.zigbee2mqtt.io/devices/E2007.html#ikea-e2007","info":"https://www.zigbee2mqtt.io/devices/E2007.html#ikea-e2007","x":250,"y":60,"wires":[]},{"id":"84ae7545.8ffa28","type":"function","z":"1bec2846.4029b8","name":"off","func":"msg.payload = {\"fan_mode\": \"off\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":20,"wires":[["cb50b45d.9a4e28"]]},{"id":"4d2ff189.666908","type":"mqtt-broker","name":"192.168.2.4","broker":"192.168.2.4","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"protocolVersion":"4","keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
BazemanKM
Post by BazemanKM »
FireWizard wrote: Monday 24 October 2022 15:07 Hello @BazemanKM
The fan accepts strings, also for the numbers
Incoming topic in the MQTT node domoticz/out/$IDX i configured that in Domoticz.
BazemanKM
Post by BazemanKM »
New Node-RED flow that also communicates the setting on STARKVIND to Domoticz.
[{"id":"1bec2846.4029b8","type":"tab","label":"Luchtververser","disabled":false,"info":""},{"id":"92af5d9e.d6b11","type":"mqtt in","z":"1bec2846.4029b8","name":"Domoticz Luchtververser","topic":"domoticz/out/541","qos":"2","datatype":"auto","broker":"4d2ff189.666908","nl":false,"rap":false,"x":150,"y":200,"wires":[["a6e7acbe.f6401"]]},{"id":"a6e7acbe.f6401","type":"json","z":"1bec2846.4029b8","name":"","property":"payload","action":"","pretty":false,"x":370,"y":200,"wires":[["b6d70fc0.f6db5"]]},{"id":"cb50b45d.9a4e28","type":"mqtt out","z":"1bec2846.4029b8","name":"MQTT Lucht ververser","topic":"zigbee2mqtt/Luchtververser/set","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4d2ff189.666908","x":1060,"y":220,"wires":[]},{"id":"b6d70fc0.f6db5","type":"switch","z":"1bec2846.4029b8","name":"","property":"payload.svalue1","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"10","vt":"str"},{"t":"eq","v":"20","vt":"str"},{"t":"eq","v":"30","vt":"str"},{"t":"eq","v":"40","vt":"str"},{"t":"eq","v":"50","vt":"str"},{"t":"eq","v":"60","vt":"str"},{"t":"eq","v":"70","vt":"str"},{"t":"eq","v":"80","vt":"str"},{"t":"eq","v":"90","vt":"str"},{"t":"eq","v":"100","vt":"str"}],"checkall":"true","repair":false,"outputs":11,"x":530,"y":200,"wires":[["84ae7545.8ffa28"],["881d8691.c06168"],["19ce1141.d3d9ef"],["62faf9e6.ef52b8"],["5ff40353.feecbc"],["27c0f93.50b5306"],["76c5ca57.250ad4"],["dbddd75e.ec73d8"],["15badd72.2f72a3"],["b3344efa.f3137"],["a0d9040d.0eb0c8"]]},{"id":"881d8691.c06168","type":"function","z":"1bec2846.4029b8","name":"auto","func":"msg.payload = {\"fan_mode\": \"auto\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":60,"wires":[["cb50b45d.9a4e28"]]},{"id":"19ce1141.d3d9ef","type":"function","z":"1bec2846.4029b8","name":"1","func":"msg.payload = {\"fan_mode\": \"1\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":100,"wires":[["cb50b45d.9a4e28"]]},{"id":"62faf9e6.ef52b8","type":"function","z":"1bec2846.4029b8","name":"2","func":"msg.payload = {\"fan_mode\": \"2\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":140,"wires":[["cb50b45d.9a4e28"]]},{"id":"5ff40353.feecbc","type":"function","z":"1bec2846.4029b8","name":"3","func":"msg.payload = {\"fan_mode\": \"3\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":180,"wires":[["cb50b45d.9a4e28"]]},{"id":"27c0f93.50b5306","type":"function","z":"1bec2846.4029b8","name":"4","func":"msg.payload = {\"fan_mode\": \"4\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":220,"wires":[["cb50b45d.9a4e28"]]},{"id":"76c5ca57.250ad4","type":"function","z":"1bec2846.4029b8","name":"5","func":"msg.payload = {\"fan_mode\": \"5\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":260,"wires":[["cb50b45d.9a4e28"]]},{"id":"dbddd75e.ec73d8","type":"function","z":"1bec2846.4029b8","name":"6","func":"msg.payload = {\"fan_mode\": \"6\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":300,"wires":[["cb50b45d.9a4e28"]]},{"id":"15badd72.2f72a3","type":"function","z":"1bec2846.4029b8","name":"7","func":"msg.payload = {\"fan_mode\": \"7\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":340,"wires":[["cb50b45d.9a4e28"]]},{"id":"b3344efa.f3137","type":"function","z":"1bec2846.4029b8","name":"8","func":"msg.payload = {\"fan_mode\": \"8\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":380,"wires":[["cb50b45d.9a4e28"]]},{"id":"a0d9040d.0eb0c8","type":"function","z":"1bec2846.4029b8","name":"9","func":"msg.payload = {\"fan_mode\": \"9\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":420,"wires":[["cb50b45d.9a4e28"]]},{"id":"8381b23d.4aaae","type":"comment","z":"1bec2846.4029b8","name":"https://www.zigbee2mqtt.io/devices/E2007.html#ikea-e2007","info":"https://www.zigbee2mqtt.io/devices/E2007.html#ikea-e2007","x":250,"y":60,"wires":[]},{"id":"84ae7545.8ffa28","type":"function","z":"1bec2846.4029b8","name":"off","func":"msg.payload = {\"fan_mode\": \"off\"}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":20,"wires":[["cb50b45d.9a4e28"]]},{"id":"60b97aff.bb1c44","type":"function","z":"1bec2846.4029b8","name":"","func":"var fan = msg.payload;\nmsg.payload = {};\nmsg.payload.svalue = fan;\nmsg.payload.idx = 541;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":660,"wires":[["fce3f2d2.8a2a3","dd302328.678d5"]]},{"id":"fce3f2d2.8a2a3","type":"mqtt out","z":"1bec2846.4029b8","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"4d2ff189.666908","x":1130,"y":660,"wires":[]},{"id":"88e4601.78b52a","type":"switch","z":"1bec2846.4029b8","name":"","property":"payload.fan_mode","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"auto","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"7","vt":"str"},{"t":"eq","v":"8","vt":"str"},{"t":"eq","v":"9","vt":"str"}],"checkall":"true","repair":false,"outputs":11,"x":450,"y":660,"wires":[["93ce04c9.c2eed8"],["74f79a22.81c194"],["4b517e1b.c2018"],["c6291ff3.599ef"],["b7b01075.d8be1"],["b6157f8f.627c5"],["30b07e62.f97242"],["891ef81f.ee5658"],["973b8c5d.93721"],["f87a7bcc.c586f8"],["f1f5ac1.ae1635"]]},{"id":"74f79a22.81c194","type":"function","z":"1bec2846.4029b8","name":"auto","func":"msg.payload = \"10\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":540,"wires":[["60b97aff.bb1c44"]]},{"id":"4b517e1b.c2018","type":"function","z":"1bec2846.4029b8","name":"1","func":"msg.payload = \"20\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":580,"wires":[["60b97aff.bb1c44"]]},{"id":"c6291ff3.599ef","type":"function","z":"1bec2846.4029b8","name":"2","func":"msg.payload = \"30\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":620,"wires":[["60b97aff.bb1c44"]]},{"id":"b7b01075.d8be1","type":"function","z":"1bec2846.4029b8","name":"3","func":"msg.payload = \"40\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":660,"wires":[["60b97aff.bb1c44"]]},{"id":"b6157f8f.627c5","type":"function","z":"1bec2846.4029b8","name":"4","func":"msg.payload = \"50\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":700,"wires":[["60b97aff.bb1c44"]]},{"id":"30b07e62.f97242","type":"function","z":"1bec2846.4029b8","name":"5","func":"msg.payload = \"60\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":740,"wires":[["60b97aff.bb1c44"]]},{"id":"891ef81f.ee5658","type":"function","z":"1bec2846.4029b8","name":"6","func":"msg.payload = \"70\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":780,"wires":[["60b97aff.bb1c44"]]},{"id":"973b8c5d.93721","type":"function","z":"1bec2846.4029b8","name":"7","func":"msg.payload = \"80\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":820,"wires":[["60b97aff.bb1c44"]]},{"id":"f87a7bcc.c586f8","type":"function","z":"1bec2846.4029b8","name":"8","func":"msg.payload = \"90\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":860,"wires":[["60b97aff.bb1c44"]]},{"id":"f1f5ac1.ae1635","type":"function","z":"1bec2846.4029b8","name":"9","func":"msg.payload = \"100\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":900,"wires":[["60b97aff.bb1c44"]]},{"id":"93ce04c9.c2eed8","type":"function","z":"1bec2846.4029b8","name":"off","func":"msg.payload = \"0\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":500,"wires":[["60b97aff.bb1c44"]]},{"id":"1314a3fb.3b437c","type":"mqtt in","z":"1bec2846.4029b8","name":"MQTT Luchtververser","topic":"zigbee2mqtt/Luchtververser","qos":"2","datatype":"auto","broker":"4d2ff189.666908","nl":false,"rap":false,"x":140,"y":660,"wires":[["61b53324.261dac"]]},{"id":"dd302328.678d5","type":"debug","z":"1bec2846.4029b8","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1080,"y":780,"wires":[]},{"id":"61b53324.261dac","type":"json","z":"1bec2846.4029b8","name":"","property":"payload","action":"","pretty":false,"x":330,"y":660,"wires":[["88e4601.78b52a"]]},{"id":"4d2ff189.666908","type":"mqtt-broker","name":"192.168.2.4","broker":"192.168.2.4","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"protocolVersion":"4","keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
solarboy
Domoticz version: 2026.4
Post by solarboy »
I've just bought this fan and although zigbee2mqtt works the fan selector and on/off switch are not discovered correctly. The sensors are however discovered correctly. I do have nodered installed but I have never used it. Could you provide an "idiots guide" to how I can import your flow into my system?
I am able to create the selector switch with the correct values but the rest is a bit of a mystery to me.
FireWizard
Hello @solarboy,
I recommend watching this playlist: https://www.youtube.com/playlist?list=P ... qFcXBkHy-6.
The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
A better solution if you know how MQTT works is to create a Domoticz GitHub issue withe the Zigbee2MQTT config and state topics and get these fan devices supported with MQTT Auto discover gateway.
gizmocuz
Post by gizmocuz »
I do own one myself and already created an issue on the zigbee2mqtt repository
https://github.com/Koenkk/zigbee-herdsm ... ssues/6312
As you can see with MQTT explorer, the modes field only contains one option
solarboy
Post by solarboy »
FireWizard wrote: Tuesday 31 October 2023 16:29 Hello @solarboy,
Brilliant, thank you will do. Would be nice to save energy by turning if off when nobody is at home. It's a nice device at a good price.
gizmocuz
Post by gizmocuz »
Please try the latest beta version
After the update, you might have to disable the MQTT-AD hardware, delete the selector switch with the single 'Auto' mode, then enable the MQTT-AD hardware again so you get the new switch with all the modes
gizmocuz
Post by gizmocuz »
@solarboy, the 'idea' of this device is to make sure that your room is having good quality air.
If you 'disable' this device and the quality is bad, and you come home, it is still bad.
If it fixes the quality, it will turn itself off (auto mode)
solarboy
Post by solarboy »
gizmocuz wrote: Saturday 25 November 2023 9:03 @solarboy, the 'idea' of this device is to make sure that your room is having good quality air.
Yes, this is how I run it now , but often I simply open a window and I would like it to turn off when I do that, no point it cleaning at that point, and turn back on when the window is closed again. I do the same with AC and dehumidifiers.
