Zigate tradfri switch and motion sensor
Posted: Saturday 22 October 2022 18:44
by marktn
Should the tradfri switch and motion sensor work with zigate?
I have paired them, that worked. But nothing happens after that.
No motion response.
And for the button, not happens when pushing the button.
They are not in a group, just want them as a device in domoticz.
Re: Zigate tradfri switch and motion sensor
Posted: Saturday 22 October 2022 19:23
by pipiche
May be some links to investigate:
https://github.com/zigbeefordomoticz/wi ... -Remote.md
https://github.com/zigbeefordomoticz/wi ... -Motion.md
https://github.com/zigbeefordomoticz/wi ... Tradfri.md
The main issue is the Zigate which is filtering the group command.
So either your tradfri switch and/or motion sensor use the group 0x0000 and so you just have to enable Create Group 0x0000 (from the WebUI settings), or you have to pair the remote to create a group and then makes the zigate part of the group.
Instead other Coordinators which works well with the plugin are easier to play with those remote and scene controller
Posted: Saturday 22 October 2022 20:51
by marktn
enable Create Group 0x0000 (from the WebUI settings) is working!
Thanks for your fast and good support. Keep up the good word.
