Nuki 3.0 Pro without bridge
arma_esiea
Post by arma_esiea »
Somebody have already connect Nuki 3.0 Pro without bridge directly with integrate wifi on domoticz ?
https://community.openhab.org/t/nuki-3- ... /136877/24
It's support on openhab
I’ve created feature request in github [nuki] Support for Web API · Issue #13457 · openhab/openhab-addons · GitHub 11 to discuss this topic. I also did some work implementing it, it’s still work in progress but if anyone is brave enough you can try it here - https://github.com/janvyb/files/raw/mai ... APSHOT.jar 5.
You’ll need to:
Add your devices to Nuki Web 1
Generate API token with “View devices” and “Operate devices” permission
In openHAB, create new “Nuki Web Account” thing, add your token there
Run discovery, your registered devices should show up in inbox
heggink
Domoticz version: 12451
Re: Nuki 3.0 Pro without bridge
Post by heggink »
When I created the python plugin, one of my requirements was to be able to control the locks without an internet connection. That meant using the bridge API. Unfortunately, the new lock does not support the bridge API without a bridge so only the Web API will work which is exactly what I have not implemented.
It would be possible to implement it but it would be quite a bit of work for which I don't have the time.
Anyone interested to give it a go would be very welcome. It would be best if the current plugin could be enhanced rather than creating a new one.
DASHTICZ 🙃
P1 meter & solar panel
arma_esiea
It's now implemented with MQTT but i have no action in domoticz, only status
