triggering script between given hours
Adso76
Post by Adso76 »
I have PIR sensor on detecting which I want to turn on other device. But I want this to happen only between given hours. Whats wrong with the script?
on =
        devices = {
            'PIRSleeping',
            ['nightTime'] = {'between 23:00 and 06:00'}
    execute = function(domoticz, PIRSleeping)
        if (domoticz.devices("PIRSleeping").state == "Off" and (domoticz.devices == 'nightTime' and domoticz.devices == 'On')) then
            domoticz.devices('gosund').switchOn()
Domoticz Version: 4.9895 running on Raspberry Pi B 3+ (Raspbian). PCF8574 as input and output.
plugge
Re: triggering script between given hours
Post by plugge »
Assuming that 'nightTime' is a device (which I doubt) that is triggered between 23:00-06:00.
PIRSleeping hold the triggered device.
The script should/could read like:
on =
        devices = {
            'PIRSleeping',
        if domoticz.devices("PIRSleeping").state == "Off" and
     	   (PIRSleeping.name == 'nightTime' and PIRSleeping.state == 'On')
	then
if 'nightTime' is not a device then you need a different script:
on =
        devices = {
            ['PIRSleeping'] = {'between 23:00 and 06:00'}
        if domoticz.devices('PIRSleeping').state == 'Off'
	then
Adso76
Post by Adso76 »
Thanks a lot! Works perfectly! I couldn't grasp that from dzvents tutorial.
