Negative energy in graphs
Posted: Tuesday 04 October 2022 11:35
I'm using an electric dummy sensor to input APSystems solar collector data, but it reports negative energy during the day transition.
I'm not adding any event during that time, as there is no Sun and hence no solar data. This is an export of the graph from Domoticz:
This is the corresponding input through HTTP:
Any idea why Domoticz added this negative value at the day's start?
Does domoticz need the total Energy consumption over the time the sensor got added? If so is there a way to get this through the API so I can just add it?
DateTime Energie opgewekt Vermogen gegenereerd
03/10/2022 19:50 6
03/10/2022 19:55 6
03/10/2022 20:00 6
03/10/2022 20:05 6
03/10/2022 20:10 6
03/10/2022 20:15 6
04/10/2022 00:00 -2491 0
04/10/2022 07:00 1
04/10/2022 07:45 6
04/10/2022 07:50 6
04/10/2022 07:55 7
04/10/2022 08:00 30 7
04/10/2022 08:05 10
04/10/2022 08:10 11
04/10/2022 08:15 11Code: Select all
2022-10-04T05:40:32.418003556Z [EVENT]: Power 6 Watt, total energy 0.000000 kWh
2022-10-04T05:44:31.749057208Z [EVENT]: Power 6 Watt, total energy 0.000574 kWh
2022-10-04T05:49:32.339842090Z [EVENT]: Power 6 Watt, total energy 0.001182 kWh
2022-10-04T05:54:31.621538079Z [EVENT]: Power 7 Watt, total energy 0.001816 kWh
2022-10-04T05:59:32.221796126Z [EVENT]: Power 7 Watt, total energy 0.002464 kWh
2022-10-04T06:04:31.491929069Z [EVENT]: Power 10 Watt, total energy 0.003408 kWhDoes domoticz need the total Energy consumption over the time the sensor got added? If so is there a way to get this through the API so I can just add it?
