Error Unraid - Docker - Domoticz
reinestein
Domoticz version: 2023.1
Post by reinestein »
Hey there,
Setup:
Unraid 6.11.0
LinuxServer.io docker clean installed trough Apps
USB passtrough enabled with no problem.
But... It doesn't start. No webserver running at default port 8080..
When examining the log this turns up:
2022-10-02 10:36:46.074 Error: #1 /usr/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x205 [0x55d6501e9ba5]
2022-10-02 10:36:46.074 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x14420 [0x7f6a7612e420]
2022-10-02 10:36:46.074 Error: #3 /lib/x86_64-linux-gnu/libc.so.6 : gsignal + 0xcb [0x7f6a75df000b]
2022-10-02 10:36:46.074 Error: #4 /lib/x86_64-linux-gnu/libc.so.6 : abort + 0x12b [0x7f6a75dcf859]
2022-10-02 10:36:46.074 Error: #5 /usr/bin/domoticz : + 0x2ecf68 [0x55d650102f68]
2022-10-02 10:36:46.074 Error: #6 /usr/bin/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x6 [0x55d6507f6fb6]
2022-10-02 10:36:46.074 Error: #7 /usr/bin/domoticz : + 0x9e0ff1 [0x55d6507f6ff1]
2022-10-02 10:36:46.074 Error: #8 /usr/bin/domoticz : main + 0x6ac [0x55d65010415c]
2022-10-02 10:36:46.074 Error: #9 /lib/x86_64-linux-gnu/libc.so.6 : __libc_start_main + 0xf3 [0x7f6a75dd1083]
2022-10-02 10:36:46.074 Error: #10 /usr/bin/domoticz : _start + 0x2a [0x55d65012ad9a]
2022-10-02 10:36:47.070 Status: Domoticz V2022.1 (c)2012-2022 GizMoCuz
2022-10-02 10:36:47.070 Status: Build Hash: c9526851b, Date: 2022-01-31 09:34:32
2022-10-02 10:36:47.070 Status: Startup Path: /usr/share/domoticz/
2022-10-02 10:36:47.070 Error: Error opening SQLite3 database: unable to open database file
2022-10-02 10:36:47.070 Error: Domoticz(pid:1174, tid:1174('domoticz')) received fatal signal 6 (Aborted)
2022-10-02 10:36:47.070 Error: siginfo address=0x6300000496, address=0x7ffb6e25700b
2022-10-02 10:36:47.074 Error: Failed to start gdb, will use backtrace() for printing stack frame
Any thoughts/ideas?
Re: Error Unraid - Docker - Domoticz
Cannot find the domoticz database so seems to be a permission issue.
What if you try the official Domoticz docker? https://www.domoticz.com/wiki/Docker
