found my domoticz install crashed this morning. After some fiddling around, the issue seems to be with the EvoHome plugin.
After disabling it was working fine.
Checked the logs and they say the following:
2022-10-02 09:00:32.308 Error: Domoticz(pid:2157, tid:2172('Evohome')) received fatal signal 6 (Aborted)
2022-10-02 09:00:32.308 Error: siginfo address=0x86d, address=(nil)
2022-10-02 09:00:35.894 Status: Incoming Domoticz connection from: 10.0.0.4
2022-10-02 09:00:35.909 Status: Incoming connection from: 10.0.0.31
2022-10-02 09:00:35.984 Error: Thread 16 (Thread 0x6d8ff200 (LWP 2172)):
2022-10-02 09:00:35.984 Error: #0 __waitpid (options=0, stat_loc=0x6d8fd9d8, pid=2356) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2022-10-02 09:00:35.984 Error: #1 __waitpid (pid=2356, stat_loc=0x6d8fd9d8, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2022-10-02 09:00:35.984 Error: #2 0x0029121c in dumpstack_gdb(bool) ()
2022-10-02 09:00:35.984 Error: #3 0x002917e8 in signal_handler(int, siginfo_t*, void*) ()
2022-10-02 09:00:35.984 Error: #4 <signal handler called>
2022-10-02 09:00:35.984 Error: #5 raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-10-02 09:00:35.984 Error: #6 <signal handler called>
2022-10-02 09:00:35.984 Error: #7 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-10-02 09:00:35.984 Error: #8 0x7682f230 in __GI_abort () at abort.c:79
2022-10-02 09:00:35.985 Error: #9 0x0092f064 in __gnu_cxx::__verbose_terminate_handler() ()
2022-10-02 09:00:35.985 Error: #10 0x0089241c in __cxxabiv1::__terminate(void (*)()) ()
2022-10-02 09:00:35.985 Error: #11 0x00892490 in std::terminate() ()
2022-10-02 09:00:35.985 Error: #12 0x0089cf40 in __cxa_throw ()
2022-10-02 09:00:35.985 Error: #13 0x00759170 in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2022-10-02 09:00:35.985 Error: #14 0x00761b64 in Json::Value::resolveReference(char const*, char const*) ()
2022-10-02 09:00:35.985 Error: #15 0x00495314 in CEvohomeWeb::get_zone_schedule(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2022-10-02 09:00:35.985 Error: #16 0x00495e70 in CEvohomeWeb::get_dhw_schedule(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2022-10-02 09:00:35.985 Error: #17 0x0049858c in CEvohomeWeb::DecodeDHWState(CEvohomeWeb::temperatureControlSystem*) ()
2022-10-02 09:00:35.985 Error: #18 0x00498d40 in CEvohomeWeb::GetStatus() ()
2022-10-02 09:00:35.985 Error: #19 0x00498f88 in CEvohomeWeb::Do_Work() ()
2022-10-02 09:00:35.985 Error: #20 0x00906734 in execute_native_thread_routine ()
2022-10-02 09:00:35.985 Error: #21 0x76a3b494 in start_thread (arg=0x6d8ff200) at pthread_create.c:486
2022-10-02 09:00:35.985 Error: #22 0x768eedd8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
