arduino dht11 to domoticz
peterjenp
Post by peterjenp »
Hello all.
I have the following script running on my arduino for communication between my arduinoe and domoticz on my raspbery pi 3b.
I can also switch on and off closed relays via domoticz.
However, I still can't figure out how to send the temperature and air humidity from the dht11 sensor to domoticz.
the question is now also can someone tell me which lines I should add to send the data from dht11 to the arduino to domoticz?
thanks: peter
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
//#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
//#define MY_RF24_PA_LEVEL RF24_PA_LOW
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 12000000L
#define MY_BAUD_RATE 115200
#endif
// Flash leds on rx/tx/err
// #define MY_LEDS_BLINKING_FEATURE
// Set blinking period
// #define MY_DEFAULT_LED_BLINK_PERIOD 300
// Inverses the behavior of leds
// #define MY_WITH_LEDS_BLINKING_INVERSE
// Enable inclusion mode
//#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
//#define MY_INCLUSION_BUTTON_FEATURE
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set inclusion mode duration (in seconds)
//#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
//#define MY_INCLUSION_MODE_BUTTON_PIN  3
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
#include <SPI.h>
#include <MySensors.h>
#include <Bounce2.h>
#include "DHT.h"  //dht11
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#define RELAY_1  22  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define RELAY_2  23
#define RELAY_3  24
#define RELAY_4  25
#define RELAY_5  26
#define RELAY_6  27
#define RELAY_7  28
#define RELAY_8  29
#define RELAY_9  30
#define RELAY_10  31
#define RELAY_11  32
#define RELAY_12  33
#define NUMBER_OF_RELAYS  12 // Total number of attached relays                             dodać na próbę wejścia
#define RELAY_ON 1  // GPIO value to write to turn on attached relay
#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
#define DHTPIN 46 //dht11
#define DHTTYPE DHT11 //dht11
#define CHILD_ID_1 20
#define CHILD_ID_2 21
#define INPUT_1  20
#define INPUT_2  21
Bounce debouncer1 = Bounce();
Bounce debouncer2 = Bounce();
int oldValue1 = -1;
int oldValue2 = -1;
DHT dht(DHTPIN, DHTTYPE); //dht11
void before() {
  for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
    // Then set relay pins in output mode
    pinMode(pin, OUTPUT);
    // Set relay to last known state (using eeprom storage)
    digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
void setup()  {
  pinMode(INPUT_1,INPUT);
  debouncer1.attach(INPUT_1);
  debouncer1.interval(5);
  digitalWrite(INPUT_1,HIGH);
  pinMode(INPUT_2,INPUT);
  debouncer2.attach(INPUT_2);
  debouncer2.interval(5);
  digitalWrite(INPUT_2,HIGH);
dht.begin();  //dht11
void presentation()
  // Send the sketch version information to the gateway and Controller
  sendSketchInfo("Relay", "1.0");
 present(CHILD_ID_1, S_DOOR);
 present(CHILD_ID_2, S_DOOR);
    // Register all sensors to gw (they will be created as child devices)
    present(sensor, S_LIGHT);
MyMessage msg(1, V_LIGHT);
MyMessage msg2(2, V_LIGHT);
MyMessage msg3(3, V_LIGHT);
MyMessage msg4(4, V_LIGHT);
MyMessage msg5(5, V_LIGHT);
MyMessage msg6(6, V_LIGHT);
MyMessage msg7(7, V_LIGHT);
MyMessage msg8(8, V_LIGHT);
MyMessage msg9(9, V_LIGHT);
MyMessage msg10(10, V_LIGHT);
MyMessage msg11(11, V_LIGHT);
MyMessage msg12(12, V_LIGHT);
MyMessage msg13(CHILD_ID_1, V_TRIPPED);
MyMessage msg14(CHILD_ID_2, V_TRIPPED);
void loop() {
// volgenderegels zijn dht11
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float f = dht.readTemperature(true);
  float hif = dht.computeHeatIndex(f, h);
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temperature: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print(f);
  Serial.print(F("°F  Heat index: "));
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(F("°F"));
  // einde dht11
  debouncer1.update();
  int value1 = debouncer1.read();
  if (value1 != oldValue1) {
     send(msg13.set(value1 == HIGH ? 1 : 0));
     oldValue1 = value1;
       debouncer2.update();
  int value2 = debouncer2.read();
  if (value2 != oldValue2) {
     send(msg14.set(value2 == HIGH ? 1 : 0));
     oldValue2 = value2;
void receive(const MyMessage &message) {
  // We only expect one type of message from controller. But we better check anyway.
  if (message.type==V_LIGHT) {
     // Change relay state
     digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
     // Store state in eeprom
     saveState(message.sensor, message.getBool());
     // Write some debug info
     Serial.print("Incoming change for sensor:");
     Serial.print(message.sensor);
     Serial.print(", New status: ");
     Serial.println(message.getBool());
thomasbaetge
Domoticz version: 2023.1
Re: arduino dht11 to domoticz
Post by thomasbaetge »
Sorry, I may be a bit late to this party....
that's a lot of code you're having there.
I am using a couple of DHT11 with ESP8266. they are sending readings every 5 minutes via MQTT to domoticz and then go to deep sleep (otherwise you may find yourself measuring the temperature of the ESP/arduino board, if they are enclosed together.
If that's an option for you, let me know and I'll give you the code here.
