Open Weather Map not working with version 2022.1
Posted: Wednesday 28 September 2022 14:45
Hi All,
I'm having an issue getting OWM to work with Domoticz 2022.1 (same issue running on both a Raspberry pi and also a Windows 10 machine as a test)
I enable new devices to be added.
Configure the hardware using my API key and location. I change the default forecast to use OWM.
My issue is that I do not get any additional devices created and I see errors in the error log:
I know the API key and the connectivity to OWM is okay as I see this in the status log after I configure. I use place,country and the api returns the city ID and Lat/Long.
The status logs show: (location details removed in this snippet, but they are correct)
If I manually CURL the OWM API from within a SSH session, I get the data returned. The forecast screen also works correctly, so it's not a connectivity issue either.
OWM has never worked, so I don't see that the issue is related to some leftovers from a previous upgrade.
I've a number of other devices connected via Z-Wave and a P1 sensor which all work perfectly.
Any help would be gratefully received.
Thank you in advance.
Cheers
Kevin
Error: Weather: Error getting http data!The status logs show: (location details removed in this snippet, but they are correct)
2022-09-28 10:23:51.088 Status: New sensors allowed for 5 minutes...
2022-09-28 10:24:21.555 Status: Weather: Using specified location (City XXXXXXXX, YY)!
2022-09-28 10:24:21.869 Status: Weather: City (1234567)-> Lat/Long = 50.XXXX,4.YYY
2022-09-28 10:24:21.869 Status: Weather: Updating preferences for forecastscreen to use OpenWeatherMap!
2022-09-28 10:24:21.870 Status: Weather: Started
Cheers
Kevin
