ZwaveJS2MQTT already deprecated?
Posted: Sunday 25 September 2022 18:08
by dime
While I've never had major problems with OZW, I imagine that if you do, you'll want to figure out possible other alternatives. But I was surprised to see that since 2022.1 OZW is deprecated, things apparently escalate quickly.
So I waited a long time to update to ZwaveJS2MQTT, hoping that most of the problems and initial habituation issues had been resolved.
Using the manual at https://www.domoticz.com/wiki/ZwaveJS2MQTT I did some testing on a dummy system, but after a few days it turns out the link on that site to zwave-js@github was deprecated.
What is going on here? Is ZwaveJS2MQTT also deprecated, and might it be wiser to wait to uninstall OZW until an alternative to ZwaveJS2MQTT is found?
Re: ZwaveJS2MQTT already deprecated?
Posted: Sunday 25 September 2022 18:32
by FireWizard
Hello @dime,
No, it is not deprecated, but there was a small name change, after introducing version 8.0.0.
See: https://github.com/zwave-js/zwave-js-ui/releases.
So we should change the link in the Wiki from https://zwave-js.github.io/zwavejs2mqtt/#/ to
https://zwave-js.github.io/zwave-js-ui/#/
So, the link in the Wiki should be adjusted.
Posted: Sunday 25 September 2022 19:31
by dime
Great, I already saw zwave-js-ui on github but didn't know it was the same.
Very well thanks for your response!
Posted: Monday 26 September 2022 11:05
On the Domoticz wiki page the links to zwavejs are modified to the new locations.
Posted: Saturday 01 October 2022 12:42
by mgugu
Do you know what was the reason to change the name ? The 2 versions are apparently the same, same ui, same behaviour ...
Posted: Saturday 01 October 2022 18:06
by FireWizard
Hi @mgugu
See https://github.com/zwave-js/zwave-js-ui/releases under 8.0.0.
Thats all I know.
