I'm using the block functionality to popup a screen with another set of blocks in it.
But I can't resize the popup screen. When in the popup screen are only 3 blocks of buttons I don't want to see the popup going almost fullscreen.
And is there a way to close the popup with a button of block itself?
Size of popup multi block window Topic is solved
Lokonli
Re: Size of popup multi block window
You can set the block parameters like:whoami wrote: Monday 19 September 2022 13:48 I'm using the block functionality to popup a screen with another set of blocks in it.
blocks['popupbutton'] = {
popup: 'popup',
frameheight: 300,
framewidth:100
No, that's not possible. (you can click on the 'X' or outside the frame or set a timeout to auto close)whoami wrote: Monday 19 September 2022 13:48
