What is wrong  [Solved]
pipiche
What is wrong
Post by pipiche »
I'm getting this error, and I do not understand what I'm doing wrong ?
Ligne 26 is if prise.state == 'Off' and (timer.trigger == START_TIME ) then
Sep 09 09:30:02 pi3 domoticz[23326]: 2022-09-09 09:30:02.201 Status: dzVents: Info: ------ Start external script: recharge-aspirateur.lua:, trigger: "every 5 minutes"
Sep 09 09:30:02 pi3 domoticz[23326]: 2022-09-09 09:30:02.201 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler recharge-aspirateur
Sep 09 09:30:02 pi3 domoticz[23326]: 2022-09-09 09:30:02.201 Error: dzVents: Error: (3.1.8) /var/lib/domoticz/scripts/dzVents/scripts/recharge-aspirateur.lua:26: attempt to index a nil value (global 'timer')
Sep 09 09:30:02 pi3 domoticz[23326]: 2022-09-09 09:30:02.201 Status: dzVents: Info: ------ Finished recharge-aspirateur.lua
local GENERAL = 'Grenoble General'
local PRISE = 'Prise Aspirateur'
local CONSO = 'Prise Aspirateur Power'
local START_TIME = 'at 01:00'
local LOGGING = false
	active = true,
		['timer'] = {
			'every 5 minutes',  -- checking if we are still charging
			START_TIME          -- switch on the plug
	execute = function(domoticz)
		local prise = domoticz.devices( PRISE )
		local power = domoticz.devices( CONSO )
		local general = domoticz.devices( GENERAL )
		if LOGGING then
			domoticz.log('Prise State: ' .. prise.state .. ' LastUpdate: ' .. prise.lastUpdate.minutesAgo .. ' Power: ' .. power.actualWatt .. ' Trigger: ' .. timer.trigger)
		if general.bState then
				-- Check if it is time to start the plug
				if LOGGING then domoticz.log('Lancement de la Recharge') end
				prise.switchOn()
			elseif prise.state == 'On' and prise.lastUpdate.minutesAgo > 7 and power.actualWatt < 5 then
				-- Leave time for the Power to be reported
				-- and finaly if we have only small power then stop the plug
				if LOGGING then domoticz.log('Recharge terminée')end
				prise.switchOff()
willemd
Re: What is wrong
Post by willemd »
In the "On" section, why is your timer between [] and '' ?
['timer'] = {
instead of
timer = {
boum
Domoticz version: 4.10717
Re: What is wrong  [Solved]
Post by boum »
should be
execute = function(domoticz, timer)
