FGS211 power relay is set-up and features 3 groups, the 3rd one as explained in the relay documentation beeing the lifeline one. If I understand well, this group is dedicated to reporting state to the controller as explained in Association chapter 4 of the documentation:
However the switch does not uptade at Domoticz level. In order to get it updated, enable polling has to be enabled. Among others, I've got a door sensor that updates whenever its states changes.
Running Domoticz stable 20221
What could be wrong?
Thank you
FGS211: state does not update automatically
Number8
- Domoticz version: 2022.1
Debian buster on NUC and three RPi with buster.
- gizmocuz
Re: FGS211: state does not update automatically
What happens when you also add the controller (node 1) in the first group ?
Also, consider switching to ZWaveJS2MQTT (and in domoticz use the MQTT Auto Discovery hardware) as OZW is no longer developed and will be deprecated very soon
Number8
Thank you gizmocuz to help me on this matter. So controller has been added to switch group 1. Strange thing the display reports 1.1 instead of 1. Is it expected?gizmocuz wrote: Wednesday 07 September 2022 11:35 What happens when you also add the controller (node 1) in the first group ?
Anyhow, dz switch still does not update. I deactivated / reactivated zwave: no change
I then removed group 3 association to controller (1). As soon zwave is restarted this association is back.
Thank yo for warning me regarding OZW deprecation. I already heavily use MQQT (non discovery mode) for communication with other systems. Are there any forseable side effects if I replace MQTT non discovery mode by MQTT discovery mode to the current configuration?
