Page 1 of 2
Cant get MQTT output into domoticz
Posted: Friday 02 September 2022 11:56
by MikeyMan
Hi All,
i'm fiddling around with NodeRed, to get some API output into domoticz.
I think i've come some ways already.
I've been able to post an MQTT message in the right folder:
2022-09-02 11_57_20-MQTT Explorer.png (9.27 KiB) Viewed 4413 times
And added the dummy to domoticz:
2022-09-02 Domoticz.png (14.4 KiB) Viewed 4414 times
However, the data isn't showing up.
Any thoughts?
Re: Cant get MQTT output into domoticz
Posted: Friday 02 September 2022 13:01
Do you have a MQTT Client gateway created that is listening to the broker? See wiki:
https://www.domoticz.com/wiki/MQTT#Add_ ... Gateway.22
What does the Domoticz log file say? does it see an incoming message?
Posted: Friday 02 September 2022 13:50
by MikeyMan
I think i did:
2022-09-02 13_48_01-domoticz.png (45.67 KiB) Viewed 4398 times
And i see the 'out' folder being filled nicely.
I see some stuff coming along from my earlier more difficult tries:
2022-09-02 13_49_22-mqtt.png (123.75 KiB) Viewed 4398 times
So something is happening i'd think.
thought i'd try it out with a simple text. But no clue why nothing is coming along.
Posted: Friday 02 September 2022 13:52
by MikeyMan
Also; having to manually create devices and idx's isnt the most convenient...
Posted: Friday 02 September 2022 14:24
by MikeyMan
Trying this:
http://10.0.0.4:8080/json.htm?type=comm ... value=text
i also get an error... No clue if this is correct though.
"status" : "ERR"
Posted: Friday 02 September 2022 15:01
Perhaps add nvalue=0 in url or "nvalue":0 in MQTT load.
Posted: Friday 02 September 2022 16:40
by MikeyMan
waltervl wrote: Friday 02 September 2022 15:01 Perhaps add nvalue=0 in url or "nvalue":0 in MQTT load.
No luck i'm afraid... :(
Posted: Friday 02 September 2022 17:01
by MikeyMan
Even deleted the MQTT hardware and re-added, but no luck
Posted: Saturday 03 September 2022 9:45
by FireWizard
Could you please post your Node Red flow?
Posted: Saturday 03 September 2022 16:35
by MikeyMan
FireWizard wrote: Saturday 03 September 2022 9:45 Could you please post your Node Red flow?
Of course... Work in progress of course ;)
[{"id":"743a62898f598be4","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"aba1dab9e8709847","type":"http request","z":"743a62898f598be4","name":"Get Version","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.199:8443/enduser-mobile-web/1/enduserAPI/apiVersion","tls":"d141c56ce52dcd5d","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":610,"y":120,"wires":[["d58a15c4c09ebd12","9c0b16ffc945e95a","8690d30946cad6ca"]]},{"id":"d58a15c4c09ebd12","type":"debug","z":"743a62898f598be4","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":100,"wires":[]},{"id":"9c0b16ffc945e95a","type":"debug","z":"743a62898f598be4","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.protocolVersion","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":160,"wires":[]},{"id":"1c61a2e3f17004cc","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":120,"wires":[["aba1dab9e8709847"]]},{"id":"8690d30946cad6ca","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"Tahoma","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":920,"y":240,"wires":[]},{"id":"fc6d9990e9735efe","type":"http request","z":"743a62898f598be4","name":"Get Devices","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.161:8443/enduser-mobile-web/1/enduserAPI/setup/devices","tls":"d141c56ce52dcd5d","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":430,"y":420,"wires":[["792793a85f7af9e3","0f5c255927c3a287"]]},{"id":"0d0b145a46d08eb6","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":420,"wires":[["fc6d9990e9735efe"]]},{"id":"27bcb8ebe2e66553","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":1350,"y":420,"wires":[]},{"id":"14b2125b610f82a3","type":"debug","z":"743a62898f598be4","name":"debug 8","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.label","targetType":"msg","statusVal":"","statusType":"auto","x":720,"y":500,"wires":[]},{"id":"792793a85f7af9e3","type":"debug","z":"743a62898f598be4","name":"debug 9","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":480,"y":500,"wires":[]},{"id":"390f410fdeae6dec","type":"change","z":"743a62898f598be4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"\"domoticz/in/\" & msg.payload.label","tot":"jsonata"},{"t":"delete","p":"payload.creationTime","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":420,"wires":[["0d414e1eda85b389","164e4e3ca1fddfca","1f4ca39d34a2136f"]]},{"id":"0d414e1eda85b389","type":"debug","z":"743a62898f598be4","name":"debug 10","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":500,"wires":[]},{"id":"0f5c255927c3a287","type":"split","z":"743a62898f598be4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":420,"wires":[["14b2125b610f82a3","390f410fdeae6dec"]]},{"id":"164e4e3ca1fddfca","type":"function","z":"743a62898f598be4","name":"function 1","func":"//if(msg.payload.deviceURL === \"io://2017-8871-5701/3196925\")\n//{\n//    return msg;\n//}\n\nif (msg.payload.deviceURL === \"io://2017-8871-5701/3196925\") \n    {\n    msg.payload = { \"idx\": 388, \"svalue\": \"test\", \"nvalue\": 0}    \n    return msg;\n    }\n\n\n//{ \"command\": \"udevice\", \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n//{ \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1140,"y":420,"wires":[["27bcb8ebe2e66553","5569758a44d2d493"]]},{"id":"5569758a44d2d493","type":"debug","z":"743a62898f598be4","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":500,"wires":[]},{"id":"1f4ca39d34a2136f","type":"debug","z":"743a62898f598be4","name":"debug 12","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1220,"y":320,"wires":[]},{"id":"d141c56ce52dcd5d","type":"tls-config","name":"TLS","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false,"alpnprotocol":""},{"id":"92e5b2c.00a8b5","type":"mqtt-broker","name":"MQTT (NAS)","broker":"10.0.0.4","port":"1883","clientid":"Node_Red_Client","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Posted: Saturday 03 September 2022 18:49
by FireWizard
Hello @MikeyMan,
Thanks for posting your flow.
I will look at it later today or tomorrow.
But before that, can you confirm, as I saw some issues in your screenshots, the following:
1. Your Domoticz is running with IP address 10.0.0.4. Running the default port 8080.
2. Your MQTT broker is using this IP address 10.0.0.4 as well with the default port 1883. Is it Mosquitto? See screenshot 02 Sep 2022, 13:50
3. In Domoticz you created a "Text" device, with IDX 388.
For now to start it is the best way to do it manually. Later on you may want to go to "auto detection".
You tried to send some data to Domoticz. From where? Browser or did you try Node Red?
At least there is one thing, that is incorrect.
See your screenshot of MQTT Explorer (Your post of 02 Sep 2022, 11:56 ).
The JSON object you published ( {"command":"udevice", "idx":388,"svalue":"test"} ) has been published to the wrong topic and so Domoticz will never be able to handle it correctly.
The topic should be: domoticz/in and not domoticz/in/Zonwering Balkonraam
Posted: Saturday 03 September 2022 19:06
by MikeyMan
Thanks for the hints. I thought that based on the topic, you could differentiate between the devices, same as domotic does on the out folder? Could be the wrong assumption of course :)
Would make it easier to see what messages come in for which device?
As per your questions:
Domoticz is running on 10.0.0.30:8080 (Rpi)
NodeRed is running on 10.0.0.4:1880
Mosquitto is running on 10.0.0.4:1883
Edit:removed the topic, but no luck yet...
Posted: Saturday 03 September 2022 21:40
by FireWizard
Hello @MikeyMan,
It is possible to install more than one hardware device "MQTT Client Gateway with LAN interface".
In this case you can configure these with different topics, e.g. domoticz/in/topic1 and domoticz/in/topic2.
Disable domoticz/out on one of them.
However, I doubt, if you install many hardware devices of type "MQTT Client Gateway with LAN interface", that it will become easier/clearer.
In this case your test of sending a message to Domoticz (see your post 02 Sep 2022, 14:24 ), http://10.0.0.4:8080/json.htm?type=comm ... value=text. is wrong and should be http://10.0.0.30:8080/json.htm?type=com ... value=text
You should not remove the topic, but change the topic to "domoticz/in" (without quotes)
Let's go to your flow.
I do not know your network setup, but I saw a few things that attracted my attention.
1. In the first HTTP Request node, you use IP address 10.0.0.199, while in the second you use 10.0.0.161. Is that correct?
2. In the "Change" node, you use a JSONata expression in order to set the topic. As discussed earlier, in Domoticz the topic, that Domoticz subscribes to, has been set to domoticz/in. As said before you can define multiple hardware devices for MQTT, but this is currently not the case.
In my opinion you can remove the complete Change node. There is no need to delete msg.payload.creationTime .
3. In the "Function" node, you can remove "nvalue": 0, as there is no need for it. It does not harm either.
4. In the MQTT output node, insert the topic domoticz/in.
That should work for you.
I see also a number of things in your screenshot, posted 02 Sep 2022, 13:50
What is happening with the Shelly and Heishamon. There is one client that failed to start and to connect with the MQTT server at IP address 10.0.0.4.
I see also that you did sent a lot of messages to domoticz/in, which Domoticz cannot understand. (Invalid/Unhandled data received!)
You cannot define your own payload for MQTT, but has to confirm to the Domoticz JSON format.
An example you can find at: https://piandmore.wordpress.com/2019/02 ... -domoticz/ and at https://www.domoticz.com/wiki/MQTT
Let me know.
Posted: Sunday 04 September 2022 7:40
by MikeyMan
Thanks for the tips! I'm struggling a bit from my holiday address, but I'll get back asap.
Posted: Monday 05 September 2022 10:34
by MikeyMan
FireWizard wrote: Saturday 03 September 2022 21:40 Hello @MikeyMan,
I was hoping that the in-folder could work the same as the out folder. With a topic per device. But if that's not the case, we'll have to make it work
Agree, probably not.
That was mighty stupid of me... I am doing too many things at the same time. Amongst others, I was trying to move my domoticz setup from pi to Nas, with master slave. That's why I messed up the IPs. My apologies.
Although the good news is that the JSON itself was correct. And with the right op it's working now.
Did that now. However I can't seem to get mqtt working with port forwarding from my holiday address.
Yes, I changed the IP address of the tahoma box.
Think youre right. I was trying to make the output more readable. Change node was the first thing I tried. But with the function node that's now obsolete.
Tried that on a suggestion earlier in this topic. I'll remove it again.
I'll fiddle around some more. Although without visibility on the mqtt server. Probably a bit in the blind.
Let me know.
Again, thans for your elaborate help, keep you posted
Posted: Monday 05 September 2022 11:21
by FireWizard
Hi @MikeyMan,
Can you send a screenshot of the output of the Debug Node, called "debug 11", at least if you use the latest Node Red release (3.0.2).
This is the Debug Node, connected to the Function node, called "function 1".
Posted: Monday 05 September 2022 17:29
by MikeyMan
FireWizard wrote: Monday 05 September 2022 11:21 Hi @MikeyMan,
Here you go:
Took removal of the time stamp out.
Writing value to text with JSON succeeded. Even remotely ;)
Still no luck from nodered though.
 [{"id":"743a62898f598be4","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"aba1dab9e8709847","type":"http request","z":"743a62898f598be4","name":"Get Version","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.199:8443/enduser-mobile-web/1/enduserAPI/apiVersion","tls":"d141c56ce52dcd5d","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":610,"y":120,"wires":[["d58a15c4c09ebd12","9c0b16ffc945e95a","8690d30946cad6ca"]]},{"id":"d58a15c4c09ebd12","type":"debug","z":"743a62898f598be4","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":100,"wires":[]},{"id":"9c0b16ffc945e95a","type":"debug","z":"743a62898f598be4","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.protocolVersion","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":160,"wires":[]},{"id":"1c61a2e3f17004cc","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":120,"wires":[["aba1dab9e8709847"]]},{"id":"8690d30946cad6ca","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"Tahoma","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":920,"y":240,"wires":[]},{"id":"fc6d9990e9735efe","type":"http request","z":"743a62898f598be4","name":"Get Devices","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.161:8443/enduser-mobile-web/1/enduserAPI/setup/devices","tls":"d141c56ce52dcd5d","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":430,"y":420,"wires":[["792793a85f7af9e3","0f5c255927c3a287"]]},{"id":"0d0b145a46d08eb6","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":420,"wires":[["fc6d9990e9735efe"]]},{"id":"27bcb8ebe2e66553","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":1350,"y":420,"wires":[]},{"id":"14b2125b610f82a3","type":"debug","z":"743a62898f598be4","name":"debug 8","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.label","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":500,"wires":[]},{"id":"792793a85f7af9e3","type":"debug","z":"743a62898f598be4","name":"debug 9","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":480,"y":500,"wires":[]},{"id":"390f410fdeae6dec","type":"change","z":"743a62898f598be4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"\"domoticz/in/\"","tot":"jsonata"},{"t":"delete","p":"payload.creationTime","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":420,"wires":[["0d414e1eda85b389","164e4e3ca1fddfca","1f4ca39d34a2136f"]]},{"id":"0d414e1eda85b389","type":"debug","z":"743a62898f598be4","name":"debug 10","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":500,"wires":[]},{"id":"0f5c255927c3a287","type":"split","z":"743a62898f598be4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":420,"wires":[["14b2125b610f82a3","390f410fdeae6dec"]]},{"id":"164e4e3ca1fddfca","type":"function","z":"743a62898f598be4","name":"function 1","func":"//if(msg.payload.deviceURL === \"io://2017-8871-5701/3196925\")\n//{\n//    return msg;\n//}\n\nif (msg.payload.deviceURL === \"io://2017-8871-5701/3196925\") \n    {\n    msg.payload = { \"idx\": 388, \"svalue\": \"test 1\" } \n  //  msg.topic = { \"domoticz/in\" }\n    return msg;\n    }\n\n\n//{ \"command\": \"udevice\", \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n//{ \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1140,"y":420,"wires":[["27bcb8ebe2e66553","5569758a44d2d493"]]},{"id":"5569758a44d2d493","type":"debug","z":"743a62898f598be4","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":500,"wires":[]},{"id":"1f4ca39d34a2136f","type":"debug","z":"743a62898f598be4","name":"debug 12","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1220,"y":320,"wires":[]},{"id":"d141c56ce52dcd5d","type":"tls-config","name":"TLS","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false,"alpnprotocol":""},{"id":"92e5b2c.00a8b5","type":"mqtt-broker","name":"MQTT (NAS)","broker":"10.0.0.4","port":"1883","clientid":"Node_Red_Client","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Posted: Monday 05 September 2022 17:43
by MikeyMan
At this point of course frankly this has nothing to do with an api call, but just trying to get the simplest output into domoticz.
Tried an even simpler flow:
 [{"id":"743a62898f598be4","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"aba1dab9e8709847","type":"http request","z":"743a62898f598be4","name":"Get Version","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.199:8443/enduser-mobile-web/1/enduserAPI/apiVersion","tls":"d141c56ce52dcd5d","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":610,"y":120,"wires":[["d58a15c4c09ebd12","9c0b16ffc945e95a","8690d30946cad6ca"]]},{"id":"d58a15c4c09ebd12","type":"debug","z":"743a62898f598be4","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":100,"wires":[]},{"id":"9c0b16ffc945e95a","type":"debug","z":"743a62898f598be4","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.protocolVersion","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":160,"wires":[]},{"id":"1c61a2e3f17004cc","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":120,"wires":[["aba1dab9e8709847"]]},{"id":"8690d30946cad6ca","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"Tahoma","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":920,"y":240,"wires":[]},{"id":"fc6d9990e9735efe","type":"http request","z":"743a62898f598be4","name":"Get Devices","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://10.0.0.161:8443/enduser-mobile-web/1/enduserAPI/setup/devices","tls":"d141c56ce52dcd5d","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":430,"y":420,"wires":[["792793a85f7af9e3","0f5c255927c3a287"]]},{"id":"0d0b145a46d08eb6","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":420,"wires":[["fc6d9990e9735efe"]]},{"id":"27bcb8ebe2e66553","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":1350,"y":420,"wires":[]},{"id":"14b2125b610f82a3","type":"debug","z":"743a62898f598be4","name":"debug 8","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.label","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":500,"wires":[]},{"id":"792793a85f7af9e3","type":"debug","z":"743a62898f598be4","name":"debug 9","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":480,"y":500,"wires":[]},{"id":"390f410fdeae6dec","type":"change","z":"743a62898f598be4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"\"domoticz/in/\"","tot":"jsonata"},{"t":"delete","p":"payload.creationTime","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":420,"wires":[["0d414e1eda85b389","164e4e3ca1fddfca","1f4ca39d34a2136f"]]},{"id":"0d414e1eda85b389","type":"debug","z":"743a62898f598be4","name":"debug 10","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":500,"wires":[]},{"id":"0f5c255927c3a287","type":"split","z":"743a62898f598be4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":420,"wires":[["14b2125b610f82a3","390f410fdeae6dec"]]},{"id":"164e4e3ca1fddfca","type":"function","z":"743a62898f598be4","name":"function 1","func":"//if(msg.payload.deviceURL === \"io://2017-8871-5701/3196925\")\n//{\n//    return msg;\n//}\n\nif (msg.payload.deviceURL === \"io://2017-8871-5701/3196925\") \n    {\n    msg.payload = { \"idx\": 388, \"svalue\": \"test 1\" } \n  //  msg.topic = { \"domoticz/in\" }\n    return msg;\n    }\n\n\n//{ \"command\": \"udevice\", \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n//{ \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1140,"y":420,"wires":[["27bcb8ebe2e66553","5569758a44d2d493"]]},{"id":"5569758a44d2d493","type":"debug","z":"743a62898f598be4","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":500,"wires":[]},{"id":"1f4ca39d34a2136f","type":"debug","z":"743a62898f598be4","name":"debug 12","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1220,"y":320,"wires":[]},{"id":"da22f822bb4835c8","type":"inject","z":"743a62898f598be4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":640,"wires":[["887e1a675e7b7458"]]},{"id":"887e1a675e7b7458","type":"function","z":"743a62898f598be4","name":"function 1","func":"//if(msg.payload.deviceURL === \"io://2017-8871-5701/3196925\")\n//{\n//    return msg;\n//}\n\n\n    msg.payload = { \"idx\": 388, \"svalue\": \"Testing MQTT to Domoticz\" } \n    return msg;\n\n//{ \"command\": \"udevice\", \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n//{ \"idx\" : 7, \"nvalue\" : 0, \"svalue\" : \"90;2975.00\" }\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":640,"wires":[["f708f986c4e688fe","f5d9c199645c3960"]]},{"id":"f708f986c4e688fe","type":"mqtt out","z":"743a62898f598be4","name":"","topic":"domoticz/in","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"92e5b2c.00a8b5","x":670,"y":640,"wires":[]},{"id":"f5d9c199645c3960","type":"debug","z":"743a62898f598be4","name":"debug 13","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":700,"wires":[]},{"id":"d141c56ce52dcd5d","type":"tls-config","name":"TLS","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false,"alpnprotocol":""},{"id":"92e5b2c.00a8b5","type":"mqtt-broker","name":"MQTT (NAS)","broker":"10.0.0.4","port":"1883","clientid":"Node_Red_Client","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
And this is working somehow.
Seems that the switch node is the culprit?
Posted: Monday 05 September 2022 21:41
by FireWizard
Hello @MikeyMan
As I see the output is correct and so should display the text "test" and "test 1" respectively, if at least the sensor with idx 388 is a "Text" sensor.
That should work and this text string has been sent by the MQTT output node of your Node Red flow.
So I do not understand
Well does it work or not. You should see the text "test" and "test 1" The word "somehow" does not make it clearer.
You wrote also:
So it is time to look at the output of the API call.
Can you show the output of "debug 9"?
Posted: Monday 05 September 2022 22:12
by MikeyMan
FireWizard wrote: Monday 05 September 2022 21:41 Hello @MikeyMan
You wrote also:
Thing is, when I enter the topic manually in the mqtt output node, it is working. When I replace the msg.topic in the change node, it doesn't. So might be I wasn't using that in the right way, although the output looked correct in mqtt explorer.
Don't know what the difference between these two is. In the screenshot, the output of the debug node looks slightly different.
As you can see from the NodeRed JSON, I'm not really using the API call yet. That's the next step, now that output is showing up in domoticz :)
