afterSec() cancels previous afterSec()
Posted: Thursday 01 September 2022 21:11
I have an event that when a certain temp sensor is >= X then it sends an switchOff().afterSec(900) command. So when the value reaches X, I want to send the OFF command to the device 900 seconds later.
But the temp sensor gets updates every approx 60 seconds. Eventually the OFF command is never sent as I expect that the next minute the afterSec() command will overwrite the previous queue command. Eventually the OFF command is always scheduled, net never met.
Is there a function to solve this? I can create a dummy device and set the 'new' value and only send the switchOff().afterSec(900) command when the dummy value is not off, but this is not a nice solution.
Is there a way to read the queue and if there is already a switchOff() command in the queue, then ignore, if there's nothing in the queue, then schedule the command.
