Fibaro Wall Plug: How to reset the energy meter?
kimhav
- Domoticz version: 2023.2
Looking at the Fibaro wall plug device value in the hardware controller section for the RaZberry2 there doesn't seem to be any function to reset the energy meter but seems possible when viewing this thread at Home Assistant. Would be quite nice to be able to reset the energy meter in the device without having to perform a device reset. Is this already possible in Domoticz?
- gizmocuz
Re: Fibaro Wall Plug: How to reset the energy meter?
Assuming you are using zwavejs2mqtt, check if you can set this parameter in the zwavejs2mqtt web gui, if this parameter is not there, maybe request a configuration file update to zwavejs2mqtt
If you hard reset the device (with the button), I suspect it will reset the counter as well ?
kimhav
Correct hard reset of the device will reset the counter; but that would mean to include it once again, so want to avoid this. But, thanks for pointing to zwavejs2mqtt I'll see what I'll figure out.
- gizmocuz
hmm also the kwh counter is just a value, if you delete the utility sensor in domoticz it will start counting again, meaning the total usage per hour/day is new
