REST-API JSON Use MikroTik router as presence-detection in Domoticz (SOLVED)
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
I'm reading my MikroTik router (RB2011UiAS-2HnD-IN) out through REST-API and get a json readout back like this;
I'm reading all dhcp-server-leases with status 'waiting', those are the devices away/not home/ The switch Earn will turn off then, like you see here;
[{".id":"*123","address":"192.168.xx.xx","address-lists":"","blocked":"false","client-id":"123456789","comment":"Laptop Earn","dhcp-option":"","disabled":"false","dynamic":"false","host-name":"LAPTOP-2018","last-seen":"14h4m17s","mac-address":"123456789","radius":"false","server":"defconf","status":"waiting"},{".id":"*124","address":"192.168.xx.xx","address-lists":"","age":"6d23h13m33s","blocked":"false","client-id":"123456789","comment":"iPhone_Earn","dhcp-option":"","disabled":"false","dynamic":"false","last-seen":"5h23m42s","mac-address":"123456789","radius":"false","server":"defconf","status":"waiting"}]
through
local api_data = domoticz.utils.fromJSON(item.data)
i'll convert this to something like this
2022-08-17 12:31:01.922 Status: dzVents: 1:
2022-08-17 12:31:01.922 Status: dzVents:  client-id: 123456789
2022-08-17 12:31:01.922 Status: dzVents:  last-seen: 11h4m15s
2022-08-17 12:31:01.922 Status: dzVents:  .id: *123
2022-08-17 12:31:01.922 Status: dzVents:  host-name: LAPTOP-2018
2022-08-17 12:31:01.923 Status: dzVents:  disabled: false
2022-08-17 12:31:01.923 Status: dzVents:  address: 192.168.xx.xx
2022-08-17 12:31:01.923 Status: dzVents:  status: waiting
2022-08-17 12:31:01.923 Status: dzVents:  server: defconf
2022-08-17 12:31:01.923 Status: dzVents:  radius: false
2022-08-17 12:31:01.923 Status: dzVents:  address-lists:
2022-08-17 12:31:01.923 Status: dzVents:  blocked: false
2022-08-17 12:31:01.923 Status: dzVents:  mac-address: 123456789
2022-08-17 12:31:01.923 Status: dzVents:  dynamic: false
2022-08-17 12:31:01.923 Status: dzVents:  comment: Laptop Earn
2022-08-17 12:31:01.923 Status: dzVents:  dhcp-option:
2022-08-17 12:31:01.923 Status: dzVents: 2:
2022-08-17 12:31:01.923 Status: dzVents:  client-id: 123456789
2022-08-17 12:31:01.923 Status: dzVents:  last-seen: 4h57m41s
2022-08-17 12:31:01.923 Status: dzVents:  .id: *124
2022-08-17 12:31:01.923 Status: dzVents:  age: 5d23h9m9s
2022-08-17 12:31:01.923 Status: dzVents:  comment: iPhone Earn
I'll then use
notfound=string.upper(tostring(api_data[index].comment))
inside a for do loop to readout the lua table (two devices here)
If a 'waiting' device doesnt have a comment, and this notfound var is nil, it will show 'NIL' and the loop will return
Now we are at home it keeps the home switch switched on/at home
The problem that's happening is that once the person is away/not home, and the notfound var is filled with the name of the device
The actual value gathered by
(string.match(notfound, uearn) == uearn
seems correct
But supposedly there is something going on resulting in this situation Earn is turned on, 5 min later off, then on, then off, etc
I tried so many things already and really don't see what i'm doing wrong, could any of you please help me or point me in the right direction, a hint will be apreciated too
This is the script
--MAIN
		devices = {'Motion',
		           'MotionCouch',
		           --'MotionLiving',
		           'MotionStairs',
		           'Maikel',
		           'PC_Maikel_locked',
		           'Earn',
		           'Sleep'
		timer = {'every 5 minutes'},
		shellCommandResponses = {
			       'restapi'  -- must match with the callback passed to the executeShellCommand
		variables = {},
		scenes = {},
		groups = {},
		security = {},
		httpResponses = {},
		customEvents = {},
		system = {},
	data = {},
	logging = {},
        local motiondev=domoticz.devices('Motion')    -- motion sensor
        local mocouch=domoticz.devices('MotionCouch')
        --local mowork=domoticz.devices('MotionWork')
        local motionliv=domoticz.devices('MotionLiving')
        local mostairs=domoticz.devices('MotionStairs')     --motion to detect upstairs/sleep
        local presencebed=domoticz.devices('MotionBed')     --switch to register presence in the bedroom + delay
        local someone=domoticz.devices('Home')        -- info
        local sleep=domoticz.devices('Sleep')       -- helpswitch gotosleep scene
        local sleepmin=120                          --minimal amount minutes that sleep switch will be on
        local holidaybed=domoticz.devices('HolidayBed')   -- holiday
        local holiday=domoticz.devices('Holiday')   -- holiday
        local maikel=domoticz.devices('Maikel')       -- maikel home
        local earn=domoticz.devices('Earn')           -- earn home
        local maikellocked=domoticz.devices('PC_Maikel_locked')
        local laptopmaikel=domoticz.devices('LaptopMaikel')
        local laptopearn=domoticz.devices('LaptopEarn')
        local pm25us=domoticz.devices('AirQualityPM25us')
        local pm25lvl=domoticz.devices('AirQualityLevel25us')
        local pm25unsafe=56
        --local camhome=domoticz.devices('SecurityCamHome') --home switch for surveillance camera sw
        local dining=domoticz.devices('Dining')
        local couch=domoticz.devices('HueCouch')       -- light couch
        local stairs=domoticz.devices('HueStairs')     -- light stairs
        local delay=30
        local usermaikel=domoticz.variables('user1') --usermaikel.value holds 'Maikel'
        local userearn=domoticz.variables('user2')   --userearn.value holds 'Earn'
        --change MotionLiving according to any motion in the (living) room
        if (domoticz.time.matchesRule('every 4 hours') and holiday.state == 'Off' and (motiondev.lastUpdate.hoursAgo >= 15 or mocouch.lastUpdate.hoursAgo >= 15)) then
            domoticz.notify('One of the motionsensors is offline')
        if (motiondev.state == 'On' or mocouch.state == 'On' or maikellocked.state == 'Off') then
            motionliv.switchOn().checkFirst()
            motionliv.switchOff().checkFirst()
        --turn sleepswitch off and system back on when awake again
        if (sleep.state == 'On' and mostairs.state == 'On' and presencebed.state == 'On'
         and sleep.lastUpdate.minutesAgo > sleepmin and sleep.lastUpdate.minutesAgo < 1440 --sleep minimal 2 hours, 1440=one day
         and not domoticz.time.matchesRule('at 5:40-7:15 on mon,tue,wed,thu,fri')          --during going to work
         and not domoticz.time.matchesRule('between 90 minutes before sunrise and sunrise') ) then --nighttime
            sleep.switchOff()
        if (sleep.state == 'On' and (sleep.lastUpdate.minutesAgo >= 1440
         or (maikel.state == 'Off' and earn.state == 'Off' and maikel.lastUpdate.minutesAgo > 5 and earn.lastUpdate.minutesAgo > 5) )) then
            sleep.switchOff()
        --maikel comes home
        if (maikel.lastUpdate.secondsAgo < 5 and maikel.active and maikel.state == 'On' and motiondev.state == 'Off') then    --motiondev because its in the middel ot room
            if (couch.state == 'Off' or stairs.state == 'Off' or someone.lastUpdate.minutesAgo < 5) then
                domoticz.notify('Welcome home Maikel, I turn the lights on for you')
                domoticz.notify('Welcome home Maikel')
            --camhome.switchOn().checkFirst().silent()
            someone.updateAlertSensor(domoticz.ALERTLEVEL_GREEN,'SOMEONE IS IN THE LIVINGROOM')
        --maikel leaves home
        elseif (maikel.lastUpdate.secondsAgo < 5 and maikel.active and maikel.state == 'Off') then
            if (pm25us.sensorValue > pm25unsafe) then
                domoticz.notify('Have a safe trip Maikel, be careful, pm2.5 levels are '..pm25lvl.text..'!')
                domoticz.notify('Have a safe trip Maikel')
            --camhome.switchOff().checkFirst().silent()
        --earn comes home
        if (earn.lastUpdate.secondsAgo < 5 and earn.active and earn.state == 'On' and motiondev.state == 'Off') then    --motiondev because its in the middel ot room
                domoticz.notify('Welcome home Earn, I turn the lights on for you')
                domoticz.notify('Welcome home Earn')
        --earn leaves home
        elseif (earn.lastUpdate.secondsAgo < 5 and earn.active and earn.state == 'Off') then
                domoticz.notify('Have a safe trip Earn, be careful, pm2.5 levels are '..pm25lvl.text..'!')
                domoticz.notify('Have a safe trip Earn')
        --motion detected, someone home (cats downstair or were upstairs)
        --if ((motiondev.state == 'On' or mocouch.state == 'On' or mowork.state == 'On') and (motiondev.lastUpdate.secondsAgo <= 60 or mocouch.lastUpdate.secondsAgo <= 60 or mowork.lastUpdate.secondsAgo <= 60) and someone.lastUpdate.minutesAgo > 5) then  --someone.lastUpdate.minutesAgo > 5) then
        if (motionliv.state == 'On') then  --someone.lastUpdate.minutesAgo > 5) then
        --no motion for 30 min, noone there, if in sleep mode it will not check the motion detectors, the scene will turn off sleep mode after 35 min
        --elseif ((maikel.lastUpdate.minutesAgo > 5 and motiondev.state == 'Off' and mocouch.state == 'Off' and mowork.state == 'Off' and someone.lastUpdate.minutesAgo >= delay and someone.lastUpdate.minutesAgo < delay+5 and someone.color == 1) or sleep.state == 'On' and someone.color == 1) then
        elseif ((motionliv.state == 'Off' and  maikel.lastUpdate.minutesAgo > 5 and someone.lastUpdate.minutesAgo >= delay and
            if (couch.state == 'On' or stairs.state == 'On') then
                domoticz.notify('No one is in the Livingroom for '..someone.lastUpdate.minutesAgo..' min, I turn the lights off for you')
            someone.updateAlertSensor(domoticz.ALERTLEVEL_GREY,'No one is in the Livingroom').silent()
        --domoticz.log('VALUE: '..someone.color)
        --someone.updateAlertSensor(domoticz.ALERTLEVEL_GREY,'No one is in the Livingroom')
        --someone.updateAlertSensor(domoticz.ALERTLEVEL_GREEN,'SOMEONE IS IN THE LIVINGROOM')
        if (item.isTimer or item.name == 'Motion' or item.name == 'MotionCouch') then
			domoticz.executeShellCommand({
				command = 'curl --netrc-file /home/pi/domoticz/scripts/bashscrips/fietsdopje._netrc "https://MTrouter/rest/ip/dhcp-server/lease?status=waiting"',
				callback = 'restapi', -- see shellCommandResponses above.
				timeout = 20, -- Max runtime 20 seconds
        end --isTimer
        if (item.isShellCommandResponse and item.statusCode~=0 and item.callback ~= 'restapi') then
            domoticz.log('ERROR item.statusCode: '..item.statusCode..' item.callback'..item.callback, domoticz.LOG_FORCE)
--FROM HERE THE MIKROTIK DATA IS PROCESSED
       if (item.isShellCommandResponse) then -- and item.statusCode==0 and item.callback == 'restapi') then
            local umaikel = string.upper(usermaikel.value)
            local uearn = string.upper(userearn.value)
            local phone = string.upper('phone')
            local laptop = string.upper('laptop')
            --local comment1 = api_data[1].comment --array/table
            --local comment2 = api_data[2].comment
            for index, x in ipairs(api_data) do
                --domoticz.log(index .. ': '.. tostring(value), domoticz.LOG_FORCE)
                notfound2=string.upper(tostring(api_data[index].comment))
                --local text=string.match(notfound, uearn)
                --local text2=string.match(notfound, phone)
                --domoticz.log('earn: '..uearn,domoticz.LOG_FORCE)
                --domoticz.log('text: '..text,domoticz.LOG_FORCE)
                --domoticz.log('phone: '..text2,domoticz.LOG_FORCE)
                if (notfound == 'NIL') then
                    do return end                 --break out of loop when item without comment is found
                domoticz.log('notfound: '..notfound, domoticz.LOG_FORCE)
                --earn phone
                if ((string.match(notfound, uearn) == uearn) and (string.match(notfound2, phone) == phone)) then
                    earn.switchOff().checkFirst()   --finding EARN and PHONE because not home
                elseif not((string.match(notfound, uearn) == uearn) and (string.match(notfound2, phone) == phone)) then
                    earn.switchOn().checkFirst()    --should NOT find earn AND phone when at home: NOT AND = NAND gate
                --maikel phone
                if ((string.match(notfound, umaikel) == umaikel) and (string.match(notfound2, phone) == phone)) then
                    maikel.switchOff().checkFirst()
                elseif not((string.match(notfound, umaikel) == umaikel) and (string.match(notfound2, phone) == phone)) then
                    maikel.switchOn().checkFirst()
                --earn laptop
                if ((string.match(notfound, uearn) == uearn) and (string.match(notfound2, laptop) == laptop)) then
                    laptopearn.switchOff().checkFirst()
                elseif not((string.match(notfound, uearn) == uearn) and (string.match(notfound2, laptop) == laptop)) then
                    laptopearn.switchOn().checkFirst()
            end -- end for
            if (api_data == nil) then
        end --end shellCommandResponses
my Domoticz and dzvents versions;
Version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 15:34:32
dzVents Version: 3.1.8
Last edited by Maikel76 on Thursday 25 August 2022 16:20, edited 2 times in total.
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Maikel76
Re: REST-API JSON readout and inconsistent var readout
Post by Maikel76 »
No one any idea??
I found it useful in these cases to get things really back to basic and start with a minimal script, tracking for example only one user and see what happens.
Maikel76
Post by Maikel76 »
waltervl wrote: Monday 22 August 2022 9:44 I found it useful in these cases to get things really back to basic and start with a minimal script, tracking for example only one user and see what happens.
Thanks, that's good advice. I used the Unify script and rewrote the for do iPair and read into how to use, will try a few things
Do you know if there is a possibility to make a wiki page yourself once i have this working?
Yes you can, request a wiki account at user gizmocuz through PM.
But you could also create a new forum topic with the script and instructions.
Maikel76
Post by Maikel76 »
            for key,field in ipairs(api_data) do
                    local value = string.upper(api_data[key].comment)
                    local a = string.match(value, uearn)
                    if a == uearn then
                         notPresentEarn = true
                    else notPresentEarn = false
                    local b = string.match(value, phone)
                    if b == phone then
                         notPresentPhone = true
                    else notPresentPhone = false
                    local c = string.match(value, umaikel)
                    if c == umaikel then
                         notPresentMaikel = true
                    else notPresentMaikel = false
                    -- switch on or off
                    if notPresentEarn then
                    if notPresentMaikel then
            end --end for do
I'm doing something terribly stupid but i don't see what
If you could look at this code for me??
BTW the comment1 and comment2 is working but i need a loop
I do not see a mistake. Perhaps log the values that are read so you know if the switching is in the values from json or within the script.
Maikel76
Post by Maikel76 »
waltervl wrote:I do not see a mistake. Perhaps log the values that are read so you know if the switching is in the values from json or within the script.
Ok I made some logging. Will test more tomorrow. Thanks for your replies
Maikel76
Re: REST-API JSON readout and inconsistent var readout (SOLVED)
Post by Maikel76 »
Thank you again Walter vl
Through meticulously logging every variable at every step I solved the issue
In the beginning of the script umaikel and uearn changed to a more general user1 and user2
I'll request a wiki account :)
local user1=domoticz.variables('user1') --usermaikel.value holds 'Maikel'
local user2=domoticz.variables('user2')   --userearn.value holds 'Earn'
then the isShellCommandResponse is now;
            local u1 = string.upper(user1.value)
            local u2 = string.upper(user2.value)
            local notPresentu1=nil
            local notPresentu2=nil
            local notPresentPhone=nil
                    --find device
                    domoticz.log('value: '..value,domoticz.LOG_FORCE)
                    --search user2
                    local a = string.match(value, u2)
                    --domoticz.log('u2: '..tostring(a),domoticz.LOG_FORCE)
                    if a == u2 then
                         notPresentu2 = true
                    elseif (a ~= u2) or (a == nil) then
                         notPresentu2 = false
                    --domoticz.log('notPresentu2: '..tostring(notPresentu2),domoticz.LOG_FORCE)
                    --search phone
                    --domoticz.log('phone: '..tostring(b),domoticz.LOG_FORCE)
                    if b == phone then
                    elseif (b ~= phone) or (b == nil) then
                    --domoticz.log('notPresentPhone: '..tostring(notPresentPhone),domoticz.LOG_FORCE)
                    --search laptop
                    local c = string.match(value, laptop)
                    --domoticz.log('laptop: '..tostring(c),domoticz.LOG_FORCE)
                    if c == laptop then
                         notPresentLaptop = true
                    elseif (c ~= laptop) or (c == nil) then
                         notPresentLaptop = false
                    --domoticz.log('notPresentLaptop: '..tostring(notPresentLaptop),domoticz.LOG_FORCE)
                    --search user1
                    local d = string.match(value, u1)
                    --domoticz.log('u1: '..tostring(d),domoticz.LOG_FORCE)
                    if d == u1 then
                         notPresentu1 = true
                    elseif (d ~= u1) or (d == nil) then
                         notPresentu1 = false
                    --domoticz.log('notPresentu1: '..tostring(notPresentu1),domoticz.LOG_FORCE)
                    if notPresentu2 and notPresentPhone then
                        notPresentu2Phone = true
                    if notPresentu1 and notPresentPhone then
                        notPresentu1Phone = true
                    if notPresentu2 and notPresentLaptop then
                        notPresentu2Laptop = true
            end --end for do
            -- switch on or off
            domoticz.log('notPresentu2Phone: '..tostring(notPresentu2Phone), domoticz.LOG_FORCE)
            domoticz.log('notPresentu1Phone: '..tostring(notPresentu1Phone), domoticz.LOG_FORCE)
            domoticz.log('notPresentu2Laptop: '..tostring(notPresentu2Laptop), domoticz.LOG_FORCE)
            if notPresentu2Phone then
            if notPresentu1Phone then
            if notPresentu2Laptop then
Great!
Maikel76
Post by Maikel76 »
Since i didn't hear anything from gizmocuz here my script and a document howto is anyone interested.
It might contain small errors so if you see something please let me know. I know i should change the code in the case none of the devices are detected, working on that (Edit: changed this). It's working in our house already.
Documentation:
MikroTik router (at least RouterOS v7.1beta4, tested on 7.4.1 stable):
Users:
Goto system/users and add user, in this scrip user domoticz is used
Goto groups and create api-domoticz with policies; ssh, (write), read, api, restapi (write probably not needed)
Add domoticz to api-domoticz group
Certificates:
First install certificates on MikroTik router, follow this doc:
https://help.mikrotik.com/docs/display/ROS/Certificates
make sure the name of the common-name=”server” is the name of your router, setup in DNS;
DNS:
make sure dns-static includes the name used as “server” in the certificate and in the api-command in the dzvents-script
DNSserver needs to be running (default settings ok)
Services:
make sure under ip/services api-ssl is enabled and has the correct cert assigned
DHCP:
in DHCP under leases please first find the devices to be controlled in domoticz (phones laptops), makes these devices Static and add comment as follows:
<nameperson><typedevice> or <typedevice><nameperson>
e.g. iPhone Maikel, Earns-Laptop
symbols like _ , - or space are allowed, symbols like “ or ‘ should be avoided
API doc;
https://help.mikrotik.com/docs/display/ROS/REST+API
Linux (tested on raspbian buster 10):
Define a directory where the password file resides; in the script the following is used and needs to be changed;
/home/pi/domoticz/scripts/bashscrips/ as path change to your own location
The password file is named: fietsdopje._netrc change if needed but leave .netrc the same
Fill the file with;
machine MT-PietjePuk ← this is the name used as “server” used earlier
login domoticz ← user can be changed, needs to be changed in the router too
password xxxxxxxxxxxxxxxxxxxxx
Domoticz (tested on 2022.1 stable, dvvents 3.1.8):
user variable:
In Setup-More options-User variables: add two users; user1 and user2 and give them both a name
you have to use user1 and user2 as variable name, or edit the script
The var type is string
It is recommended that the var value doesn’t contain a space
events:
Make a new script as dvvents-minimal
Then copy paste the scriptcode and edit the following values;
devicenames under on={devices according to your own devices, same as starting line 24;
leave
edit
so that devices Motion and/or MotionCouch are devicenames you use to trigger if someone enters the house/livingroom
edit
	command = 'curl --netrc-file /home/pi/domoticz/scripts/bashscrips/fietsdopje._netrc "https://MT-PietjePuk/rest/ip/dhcp-server/lease?status=waiting"',
so that the path is correct and the router-dns-name is correct (in bold)
recommended to not change any settings under line 40
please note that all commented out lines beginning with domoticz.log( are for debug purposes
This script works as follows in short;
When someone walks in the living room the script is triggered, sends the api-request for dhcp-leases with status ‘waiting’, receives json data, converts that to a lua-table and reads the devices from that table as follows;
look at the comment of the device, if empty, skip, else search if the word ‘laptop’ or ‘phone’ is present together with a name of user1 or user2 (if comment with only phone or name is used this will not work)
If found than this device or person is marked notpresent and turned off
e.g. in the first comment the words ‘phone’ and ‘maikel’ in the comment ‘iPhone Maikel’ are found and the user1, which is person Maikel, is turned off. Accordingly AC and lights could be turned off
The default timeout of a dhcp-lease is 10 min, so the maximum waiting time can be 15 min (+ 5 min script execution time) after you leave the house. When entering the house the system will turn on triggered by a sensor immediately.
Code:
--MAIN
		           'MotionCouch',
		           'Maikel',
		           'Earn',
		variables = {},
		scenes = {},
		groups = {},
		security = {},
		httpResponses = {},
		customEvents = {},
		system = {},
	data = {},
	logging = {},
        end --isTimer
		--DONT CHANGE ANY SETTING UNDER THIS LINE
            --domoticz.log('user2: '..tostring(u2),domoticz.LOG_FORCE)
                    --find device
                    local value = string.upper(tostring((api_data[key].comment)))	--Edit: changed so nil is detected properly
                    domoticz.log('value: '..tostring(value),domoticz.LOG_FORCE)
                    --search user2
                    if a == u2 then
                         notPresentu2 = true
                    elseif (a ~= u2) or (a == 'NIL') then
                    --search phone
                    if b == phone then
                    elseif (b ~= phone) or (b == 'NIL') then
                    --search laptop
                    if c == laptop then
                    elseif (c ~= laptop) or (c == 'NIL') then
                    --search user1
                    if d == u1 then
                         notPresentu1 = true
                    elseif (d ~= u1) or (d == 'NIL') then
            end --end for do
            -- switch on or off
        end --end isShellCommandResponse
    end --end execute
