Latest Domoticz and SBFspot 3.9.5 not working?
Posted: Tuesday 09 August 2022 13:30
by rasper
Has anyone the latest SBFspot (3.9.5) and Domoticz (either latest stable or beta) working? I installed SBfspot using the standard way:
curl -s https://raw.githubusercontent.com/sbfspot/sbfspot-config/master/sbfspot-config | sudo bash
and SBfspot is working correctly when used from command line. When adding SBFspot to domoticz hardware I do not get any new devices (accept new devices is on) and when importing data from the sma hardware item in Domoticz it doesn’t import anything. It states no sensors found, so suspect it can’t find the database or csv files (these are generated too). Debug logging does not say anything where domoticz is looking for the data.
Anyone the golden tip?
Re: Latest Domoticz and SBFspot 3.9.5 not working?
Posted: Tuesday 09 August 2022 16:16
Did you check this wiki page for instructions and file locations:
https://www.domoticz.com/wiki/SMASpot_M ... n_Domoticz
I do not know if it is up to date. Latest modified in april 2020 so if something changed in SFBSpot during that time it could influence Domoticz integration.
Posted: Tuesday 09 August 2022 19:39
by rasper
waltervl wrote: Tuesday 09 August 2022 16:16
Yes, I did, maybe should try to set-up an older version of SBFspot, but am reluctant to stick with an old version unable to update.
Posted: Wednesday 10 August 2022 0:35
So do you have sbfspot running as a service or with crontab?
Did you copy the cfg file to the correct location?
On the wiki it is explained were to look, do you see that file?
Is your sbfspot cfg file correct?
Add SBFspot to Domoticz
In Domoticz hardware section, add "SBFSpot (SMA)", for location, enter the SBFspot.cfg path (e.g. /home/pi/SBFspot/SBFspot/bin/Release_SQLite/SBFspot.cfg)
Note that since the 19th November 2015 build it is possible to use SBFSpot files that record logs for multiple inverters by suffixing the configuration line with a colon, followed by the inverter serial number. For example:
/home/pi/SBFspot/SBFspot/bin/Release_SQLite/SBFspot.cfg:1234567890
Data retrieval method
Internally, domoticz relies on SBFspot to generate logfiles in the spot format. It is therefore important that SBFspot is kept running in the background (e.g. as cronjob). See SBFspot.cpp for details.
Search for 'OutputPath', 'Plantname', 'DateFormat', and 'TimeFormat' in the config file
Build output path filename from given config strings (sprintf(szLogFile, "%s%s-Spot-%s.csv", strftime_t(m_SBFDataPath.c_str(), atime), m_SBFPlantName.c_str(), szDateStr);)
Read the output file SMA_POLL_INTERVAL per minute (default once per minute), but only if the seconds in current time are >20 (probably to give SBFspot time to query)
Check if the last line is newer than the one we have, if so, store and update power data
Posted: Thursday 11 August 2022 22:30
by rasper
Had some time to look into it a bit more, SBFspot works, files are generated, but not being picked up by Domoticz. When trying to import historical data, I get the error “can not find sensor in database”. I looked into the SBFspot.cpp sourcecode and it seems I hit this part of the code:
//Lets create the sensor, and try again
SendMeter(0, 1, 0, 0, "SolarMain");
result = m_sql.safe_query("SELECT ID FROM DeviceStatus WHERE (HardwareID==%d) AND (DeviceID=='%q') AND (Type==%d) AND (Subtype==%d)",
m_HwdID, "00000001", int(pTypeGeneral), int(sTypeKwh));
if (result.empty())
Log(LOG_ERROR, "SBFSpot Import Old Month Data: FAILED - Cannot find sensor in database");
return;
It seems that Domoticz creates the sensor but then cant find it? Despite the error, I afterwards do have the SolarMain device in Domoticz, but without any data….
Anyone some idea?
Posted: Friday 12 August 2022 0:47
What does the log of Domoticz say? As it should give some hints on this.
History data will probably only work if there are sensors created. Did you check the devices list for new devices and activated the devices created by the gateway by pressing on the green arrow?
