Unable to change node Zwave settings
wenoi6
Post by wenoi6 »
Hi All,
I have an temp+humidity sensor I added, but Im unable to change its settings. The settings are reverted back to the old value all the time
e. It is battery powered so in Nodes there is a blue moon. I tried to wake it up before doing any settings (by pressing once), but also after refresh the moon stays. If I press Apply configuration for this device I get "Configuration sent to node. If the node is asleep, this could take a while!" But nothing happens. Also checked after two hours no logging and as soon as I go back to the settings the old settings are there:S How to fix this?
Domoticz version 2022.1
Type Zwave stick: Aeotec gen5+
Hardware type configuration: OpenZWave USB
Type sensor: Aeotec ZWA0039
BennY
Re: Unable to change node Zwave settings
Post by BennY »
the Domoticz Hardware Page is not a live view. If you want to see it live open the "Control Panel".
  • Make your Configuration
  • apply it to the device
  • Wake Up the device
  • click the refresh Button on Domoticz Hardware Page
  • when the "last seen" time stamp don't change anymore click on the device
  • you should see the last send config
You also could request the stored config in same way, just click "request......device" instead of "apply......device"
Benny
