How to assign persistentusbdevices
Posted: Wednesday 20 July 2022 16:03
To be sure that after remove usbplugs from my Pi and reconnect them without worrying which one connects where..
I try to implement the suggestions as described in the wiki. See https://www.domoticz.com/wiki/PersistentUSBDevices
But I do not fully understand these points:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-ZStick-5G"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A7XKCMHJ", SYMLINK+="ttyUSB-P1"
Can someone confirm that the above code is correct? I want to create the code on a production-system..
Another last question:
The WIKI suggests that there will be only 2 new USB-ports...
Can somebody explain that to me?
- Is this the way to be sure that it does not matter in which USB-port I plug the different devices?
- When there is no file named 99-usb-serial.rules I create it there?
- Is this a good example for that file?
In the "rules-file" they declare 5 devices..After the reboot you should have two new serial ports (ttyUSB21 and ttyUSB22), and they will always be assigned to the devices you have configured in the rules file.
