Today I installed a POPP z-weather which includes 9 values.
ZwaveJS2MQTT reads all values correct and transfers them to Domoticz as visible in the log:
2022-07-05 22:50:59.926 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_speed_velocity (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Velocity)
2022-07-05 22:51:00.027 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_temperature_air (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Air_temperature)
2022-07-05 22:51:00.128 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_illuminance (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Illuminance)
2022-07-05 22:51:00.229 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_humidity_air (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Humidity)
2022-07-05 22:51:00.329 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_pressure_barometric (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Barometric_pressure)
2022-07-05 22:51:00.430 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_temperature_dew_point (unique_id: zwavejs2mqtt_0xc19ad213_84-49-0-Dew_point
2022-07-05 22:51:00.630 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_electric_kwh_value (unique_id: zwavejs2mqtt_0xc19ad213_84-50-0-value-65538)
2022-07-05 22:51:00.731 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_battery_level (unique_id: zwavejs2mqtt_0xc19ad213_84-128-0-level)
2022-07-05 22:51:00.832 Status: MQTT Zwave: discovered: nodeID_84/nodeID_84_battery_islow (unique_id: zwavejs2mqtt_0xc19ad213_84-128-0-isLow)
However these 9 values in the log only show up in the following 6 Devices with 8 values:
1377 MQTT Zwave zwavejs2mqtt_0xc19ad213_84-50-0-value-65538 1 nodeID_84_electric_kwh_value General kWh 0.098 kWh -
1376 MQTT Zwave zwavejs2mqtt_0xc19ad213_84-50-0-value-66306 1 nodeID_84_electric_pulse_count_value General Custom Senso
1375 MQTT Zwave zwavejs2mqtt_0xc19ad213_node84 1 nodeID_84 Temp + Humidity + Baro Weather Station 5.2 C, 38 %, 953.0 hPa
1374 MQTT Zwave zwavejs2mqtt_0xc19ad213_84-49-0-Illuminance 1 nodeID_84_illuminance General Percentage 21%
1373 MQTT Zwave zwavejs2mqtt_0xc19ad213_84-49-0-Velocity 1 nodeID_84_speed_velocity General Custom Sensor 0 m/s
1372 MQTT Zwave zwavejs2mqtt_0xc19ad213_84-128-0-isLow 1 nodeID_84_battery_islow Light/Switch Switch Off
it gives me back 8 values with the main issue being the combined value of Temp/Hum/Baro. This gives me the dew_point value for temperature instead of the temperature_air value. This last one is completely missing from Domoticz devices.
Anyone an idea what is going on? I tried removing device, got zwavejs2mqtt update to latest version, got the latest domoticz beta but all to no avail.
Anyway to fix this?
Thanks much!
Eric
Domoticz + zwavejs2mqtt on ubuntu
device/value missing from zwavejs2mqtt in domoticz
- gizmocuz
Re: device/value missing from zwavejs2mqtt in domoticz
You cross posted this on GitHub as well where there is a response
eluijer
- Domoticz version: 2021.1
Could you give me the link? I don't recall posting anything on Github.. like to read the answer though. Thanks!
