WAN IP address change
Sherlock
Domoticz version: 4.10717
Post by Sherlock »
My ISP has changed my WAN ip-address.
From that moment on Domoticz is not able to communicate with external systems.
For example, Domoticz raises errors while trying to connect to:
- Prowl (for IOS push notifications)
- SolarEdge (with api-key to retrieve solar panel data).
- Telegram (also for notifications from my camera).
Is there anybody who can give me a hint on what's going on here.
I am running Domoticz v4.10717 on a Raspi 3B
Regards Bauke
Dave21w
Domoticz version: Stable
Re: WAN IP address change
Post by Dave21w »
A WAN IP change should not affect any outgoing connections, I take it the rest of your internet connected items are still functioning correctly ?
Sherlock
Post by Sherlock »
Yes any outgoing connection (apart from Domoticz) is oke.
This defect occurred immediately after my ISP changed my WAN ip.
It puzzels me.
Kind regards Bauke
Treve
Domoticz version: v4.11474
Post by Treve »
Should be Ziggo, I have the same problem.
three different Wan addresses in one day.
I’m on vacation now and not be able to reach my Domoticz.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Fredom
Domoticz version: 2025.1
Post by Fredom »
The same here.
Then I have Caiway.
No problem with the app at home, but from outside I can no longer log in to Domoticz.
Everything has always worked well and nothing has changed from my side. So this problem is with the provider
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
Treve
Post by Treve »
maybe to make it difficult for (Russian) hackers?
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Sherlock
Post by Sherlock »
@Fredom and Treve,
My ISP is SKP (a local Pijnacker provider and originally based on Caiway).
I was using Domoticz v4.10717 on Jessie.
Although the issues immediately appeared after my WAN ip was changed by SKP, they told me SKP could not help me because they are not familiar with Domoticz and I was the only one having problems.
So I decided to get a clean install and now I am running Buster with Domoticz 2022.1
No problems so far and everything is running fine.
Kind regards Bauke
Fredom
Post by Fredom »
Hi Sherlock,
i also use debian buster with domoticz 2022.1
I've never had any problems and from one day to the next I couldn't log in remotely.
I then get an error in domoticz with a login ip address and if I enter that ip address in the app then I can log in. but that is not the ip address of my router and after a day it is the same problem again.
Yours sincerely,
Fred
Users browsing this forum: willemd and 1 guest
