Communication script with investor goodwe
Posted: Wednesday 29 June 2022 18:17
by tonymer
Hello, I leave here the script to communicate directly with a goodwe inverter (EM Series, possibly it works in all of them) locally. All the data comes in the inverter's response, although I only use positions 46-47 that indicate the energy that is exported and position 88 that indicates whether the energy mentioned above is exported or imported. I have created a virtual device (Dummy) of energy use that is where I store received data. If the energy is exported it is +, if the energy is imported it is -. you have to install the socket package for Lua
If you want to get other data you can check what each position means (not all) here:
https://powerforum.co.za/topic/6931-goo ... gineering/
		timer = {
			'every 2 minutes',function(domoticz)
			end,
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(domoticz, timer)
	    package.cpath ="/usr/lib/arm-linux-gnueabihf/lua/5.3/?.so;" .. package.cpath
	    package.path = "/usr/share/lua/5.3/?.lua;" .. package.path
	    local socket = require("socket")
	    local udp = assert(socket.udp())
        local datosrecibidos
        local energiadisponible
        --ponemos timeout
        udp:settimeout(5)
        assert(udp:setsockname("*",0))
        assert(udp:setpeername("192.168.1.10",8899))
        --enviamos solicitud
        assert(udp:send("\xAA\x55\xc0\x7f\x01\x06\x00\x02\x45"))
        --recibimos cadena de datos
        datosrecibidos = udp:receive()
        --Donde almacenamos los bytes recibidos
        local bytes={}
         --convertimos los datos Recibidos a un array hexadecimal (jugamos con el array internamente)
        for i=1,datosrecibidos:len()  do
                    bytes[#bytes+1] = ('%2x'):format(datosrecibidos:byte(i,i))
        --Posiciones necesarias empezando de 1
        print("Posicion 46: "..bytes[46])
        print("Posicion 47: "..bytes[47])
        print("Posicion 88: "..bytes[88])
        --Exportando (Se asignará valor en positivo)
            if ((tonumber(bytes[88],16)==0)or(tonumber(bytes[88],16)==1)) then
                energiadisponible=tonumber(bytes[46]..bytes[47],16)
            --Importando (Se asignara valor en negativo)
            if (tonumber(bytes[88],16)==2) then
                energiadisponible=tonumber(bytes[46]..bytes[47],16)*-1
        --cerramos socket
        udp:close()
        --Asignamos al sensor virtual de energia el valor
        if (energiadisponible~=nil) then
        print("Energia disponible="..energiadisponible)
	    domoticz.devices('Energia Disponible').updateEnergy(energiadisponible)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
